blinker won't blink
Old Oct 29, 2003 | 04:08 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
blinker won't blink
My driver side blinker doesn't blink. It just turns on, no flashing. The passenger side works just fine.
Old Oct 29, 2003 | 04:19 PM
Merlin's Avatar
One of the lamps on the left side of the car has probably failed. Check them all, including the side markers.
Old Oct 29, 2003 | 06:31 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Check the Blinker Fluid level.
Old Oct 29, 2003 | 06:42 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
yea, thats what i do, the blinker fluid prolly has never been changed, so thats prolly the best thing to do, i hope this helps, and if u believe me u crack me up could be the light burn out maybe?
Old Oct 30, 2003 | 01:58 AM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
For me, it was a burnt bulb. Obviously, the light itself wasnt stuck on, but the dash indicator was. If this is what you're talking about, it's probably a burnt bulb.
Old Oct 30, 2003 | 07:35 AM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
I'm not sure if this is the same on a 3rd gen camaro, but back home my bosses 69 Gt 350 had a blinker problem, and there was a device called a "flasher" that he plugged in somewhere under the dash (like above the pedel area) and that made the blinkers work again.
I'm not sure if camaro's use flashers, but maybe it's stuck "on" ? I'm not sure how these work (or if our cars even have them), but it sounds like a possibility. Anyone know about this?
Old Oct 30, 2003 | 07:57 AM
88 IROC BOB's Avatar
It's a burnt out bulb. I had the same thing happen to me this year.
Bob
Old Nov 2, 2003 | 10:44 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Just went through this with my IROC. Turn the key to the ON position and hit the left turn signal. Get out and check to see if all the lights are on. If one isn't, try changing out that bulb. If the flasher was bad, neither side should work. The flasher is a pain to get to compared to the lights so check the lights first anyway. If you have a tilt steering wheel try moving it up/down while the left turn signal is on. My problem ended up being the wiring in the steering column. In the full up position my passenger side turn signal works fine. Move the steering wheel down even one notch and no more right turn signal. I'll "tear" into it later if it stops working in the full up position. good luck.
Old Nov 3, 2003 | 12:03 AM
SweetRide45's Avatar
Here's just a suggestion. I picked up an electronic blinker module (has a coil, cap, resistor) and it is MUCH quieter than the old thermal blinker design. It also blinks much faster as well. Just one thing, it doesn't give you the "bulb burnout" feature that the thermal ones have. I don't care, I still like it better!
Old Nov 3, 2003 | 01:36 PM
MiscCamaro's Avatar
in my 88' Fiero(which i hate) my fuel pump primes when i have the car off, with the parking lights on, and turning the left blinker!!!--but yea, its prolly just your bulb...
Old Nov 3, 2003 | 01:40 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i have a fiero....... im going to try that... lmao.
Old Nov 3, 2003 | 02:14 PM
MiscCamaro's Avatar
is your fiero your beater car too....lol
Old Nov 4, 2003 | 04:11 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
Check the flasher unit under the driver's side by steering column. Easy to get to, at least on a 1991 Camaro. I had one turn signal out, not two and the flasher unit was the culprit.
Old Aug 3, 2022 | 03:13 PM
midlifecrisis8's Avatar
Re: blinker won't blink
So I know this thread is old enough to drink in Canada, but I had this same issue after taking off the taillights to polish them and change all the bulbs. But after I replaced the bulbs all of a sudden, my passenger side rear blinker doesn't blink. Both the front and rear blinker would light up, but neither blinked anymore. Even though the rear blinked perfectly fine with the old bulb. I searched the forum and found this thread. All the blinker fluid guys were hilarious and that was just what I was looking for at my peak frustration and hours of trying to figure out what the problem was. Hilarious. But I digress. There are three types of bulbs in the taillight. A two pronger, a one pronger and then a little one. My mistake was replacing a one pronger with a two pronger. Although, I am 95ish% sure that I took a two pronger out of it- when I put a new two pronger back in, it refused to blink. Just out of a pure last ditch effort, I decided to try it with a one pronger instead to see what would happen (even though the blinker on the driver's side is a two pronger as well) and it worked! It went back to blinking. So that's my suggestion for anyone else who has this problem. Try the other bulb and see what happens.
Old Aug 3, 2022 | 03:58 PM
OrangeBird's Avatar
Car: 1989 Firebird
The fact that you were able to fit the wrong bulb in the socket is a sure sign that your socked is effed.... Look at the locating pin configurations of the two bulbs in this photo, the 1156 has it's pins directly aligned across from each other whereas the 1157 has it's pins offset (to insure the dual filament 1157 bulb can only be inserted one way, the way that lets each filament connect to it's proper circuit) . In short, you are NOT supposed to be able to install the wrong bulb in a socket that's in good condition.......
ATCFLYBOY02
Aug 6, 2012 02:40 PM
85berlinetta2.8
Dec 10, 2004 09:50 PM
Vaker
Jun 28, 2004 06:50 PM
85f-bird
Dec 28, 2003 12:32 PM
Rage13
Mar 17, 2003 08:53 PM
