Fonky downshift
Old Aug 4, 2012 | 10:03 AM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Fonky downshift
Ok so when I make a turn left or right at speed, like getting on an off ramp or a fairly sharp turn on the highway, my car down shifts into 3rd... I've never seen or heard of this before... Thoughts??
Old Aug 4, 2012 | 06:01 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Fonky downshift
That's a real nut buster, will have to think about that.
Old Aug 4, 2012 | 06:48 PM
Car: 1988 Iroc-Z
Re: Fonky downshift
My thunkin exactly...
Old Aug 4, 2012 | 06:49 PM
Pro Built Automatics's Avatar
Re: Fonky downshift
Low fluid level will cause this. Add as at least 1/2 - 2/3 quart of fluid and see what happens here.
Old Aug 4, 2012 | 09:13 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: Fonky downshift
I can confirm this. My transmission was 1qt low after the transgo full manual shift kit and when I'd try to power through a turn my RPMs would jump (VERY noticeable if the torque converter was locked up) At first I thought it was slipping. Then I was looking all dumbfounded trying to figure out how a transmission with a manual valvebody was automatically shifting on It's own
You would immediately feel the bump of it switching back to 4th after the car straightened out.
Old Aug 5, 2012 | 09:49 AM
Car: 1988 Iroc-Z
Re: Fonky downshift
Fire - I think you described exactly what mine is doing... It pisses me off but I guess I'll grab some tranny fluid today and see if that fixes it... The only issue I see is my stick already shows over by a tad...
Old Aug 5, 2012 | 10:46 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Fonky downshift
Or maybe the trans mound could be broken and putting the shift cable in a bind??
Old Aug 6, 2012 | 12:31 PM
Car: 1988 Iroc-Z
Re: Fonky downshift
Well I changed the tranny mount yesterday (it broke earlier in the week but the problem was before it broke) and I put a quart in it and that seemed to do the trick... I have a small leak that imma take care of when I get back from Boloxi this weekend... Hopefully I'll win enough to buy a 5th gen lol... I've almost convinced myself to do a LSx/T56 swap layer this month...
Old Aug 6, 2012 | 02:40 PM
Re: Fonky downshift
Once you find the "new correct level", then make a new "full mark" on the dipstick. I've seen this many times over the years.
Prodigious
Nov 7, 2020 09:23 AM
tyeo098
Nov 30, 2015 06:27 PM
someone972
Aug 30, 2015 12:52 AM
JeffP
Jan 4, 2001 11:46 PM
