Building 377 Need Advise
Old Nov 1, 2003 | 09:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I will be using my existing 350 block. Block does not need to be bored. I have Lunati Forged 5.7 Rods. Standard SpeedPro Forged -6.1CC Flat With 4 Relief to help with LPE 219 Cam. All main studs and head studs, Clevite TriMetal Bearings. Question is. What 383 crank? I was going to get an Eagle Cast but people said it does not balance right. Lunati is way over my budget. I was thinking maybe a Eagle Forged but do not know. Any good cranks under a grand I could use. 1 piece rear. Thanks
Old Nov 1, 2003 | 09:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Won't be able to stroke it with your current pistons...may want to to rethink your budget.
Old Nov 1, 2003 | 09:50 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Why wouldnt I be able to stroke it?
Old Nov 1, 2003 | 09:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, look at where your current pistons are at TDC in the block...now add about .252inches (3.48 stroke to 3.75 stroke) and you'll get the idea.
Can ya say "smack"
Old Nov 1, 2003 | 09:56 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
lolo My friend just explained that to me. Good call. Any good pistons standard bore 5.7 rod pistons to use ? with about 9:8:1 comp with 64cc heads?
Old Nov 1, 2003 | 10:00 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You need to look at head volume, etc, and piston manufacturer spec to et you close, than measure it all up.
But, I'm willing to bet someone has the combo already and can get you where you need to be.
Good luck...ya know you're probably going to have to do some clearancing too?
Old Nov 1, 2003 | 10:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yup. I looked at a cola crank but it requires a 5.85 rod. I'm all confused on this crap lol this is my first engine build.
Old Nov 2, 2003 | 06:27 AM
ede's Avatar
ede
unless you have someone that knows what they're doing helping you i'd consider sticking to a stock strokes. like was said you missed on the pistons. stay away from scat parts, eagle is good ,lunati is great. 5.7 rods or 6 shoulkd allow you to use internal balance crank, 5.56 and you'll be external and need dampner nad flywheel. there are a lot of differant parts out there you can assemble and end up with the same cubic inch, it just a matter of how much extra work and expense you go to to get there. have you measured the holes or just going by looks? also you might want to rethink the studs, you won't really need them and if you ever have a problem there's a very good change you won't get a head off with the engine in the car
Old Nov 2, 2003 | 10:53 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Since I have the whole motor apart, I always wanted a stroker and I said why would I rebuild the L98 back to normal when I can but a bradnew one for 1100 from sdpc2000. The cost of good pistons, machine shop work considering if I needed an align hone, boring and so on, and all the extras would be aournd 900 probebly. For 200 more I'd get brand new.
Old Nov 2, 2003 | 12:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Do a search. I've posted the actual deck heights, calculation methods, stock specs of various rods & pistons, etc. etc. that you need in order to figure out such things, about a hundred times. Search for message text 9.025 and my user name.
Old Nov 3, 2003 | 11:19 AM
stevedave454's Avatar
Car: 91 S10
so is it me or does the topic say 377, yet in the very first post you talk about building a 383... i'd do a 377 myself, but i dont think you can build one for under $1100
Old Nov 3, 2003 | 11:28 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I am talking about a 377 in the first post. You can also do a 377 with doing a 383 but not going 30 over.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
ZEEYAA
Apr 16, 2023 08:29 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
