speedometer hookups?
Car: Trans Am
Engine: L69
How do I hook up a mechanical speedo to a t5 with an electrical speedo output? I can never get a straight forward answer. What do I need to change on the trans to hook up the cable instead of the wire for the electric speedo? Also what speedo gears do Need with a t5 and 3.73 rearend? Thanks Kevin
You should be able to go to your GM dealer and buy the mechanical speedo drive gear. When I went to buy my new speedo gears, they had a chart on their computer that will tell you what gears you need for your rearend ratio.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You will also need what they call the sleeve (it holds the driven gear) that the cable screws on to.
Chronologically challenged. But still alive!
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
Car: 89 camaro rs
Engine: 305 tbi
wow this is old.... but can anyone verify if this is correct when doing a electric-to-mechanical speedo change in a th700r4, thanks.
and mods i apolagize if im not suposed to bring up old posts.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Problem here is.... There needs to be a gear on the output shaft of the transmission to drive the gear that actually turn the cable. (driven gear...) In order to put on there (if it is even possible....) is to remove the output shaft of the tranny, pull off the toothed wheel the speed sensor reads, and press on a gear.
Now this all depends on how the speedometer works now. Some cars used a gear driven "sensor", in that case, there already is a gear on the output shaft. In later years, the switched to the toothed wheel on the output shaft, and the sensor read it directly.
Have a look at what ya got. If there is not a gear on the output shaft of the tranny, you are going to have a fun time of this.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Elephantismo
Feb 13, 2019 12:51 AM
