fan for heater problem
Old Nov 6, 2003 | 11:50 AM
adrienne's Avatar
Car: 1989 pontiac firebird
Engine: v8
Transmission: 5speed
i am freezing here in washington and i need to know if my 89 firebird's heater needs a fuse for the fan to work, i'm hoping for
a cheap easy fix....
Old Nov 6, 2003 | 01:58 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Could be a blown fuse. Did you check? Its with all the rest of the fueses. If the fuse is good use a test light at the connection on the fan itself with the heater in the on posistion and fan high it should have power. Check the ground there also. If it's grounded good and has power tap on the blower motor with a hammer to see if it kicks on. If not its probably bad, $35 from Azone.
Old Nov 6, 2003 | 04:10 PM
Vader's Avatar
Adrienne,
Welcome Aboard!
A little more diagnosis might help.
Does the blower run on any speed (even HIGH)?
Are there any other electrical problems with the car?
Have you checked the fuse? It's in the driver's footwell area, above the trim panel. However, the fuse is only used for the lower three speeds, which is why I asked about High.
Waiting for reply....
Old Nov 6, 2003 | 07:46 PM
adrienne's Avatar
Engine: v8
heater
Thank you for your help i will check it out
i had someone from an import shop look at it and he had no idea
even where the fan motor was or if there was a fuse for the fan under the hood....
Old Nov 6, 2003 | 07:52 PM
adrienne's Avatar
Engine: v8
Originally posted by Vader
Adrienne,
Welcome Aboard!
thank you for your advise...
no it does not work at all and yes i have no door locks , but other
than that she runs hot still! i found the fuse box, but, if i could stand on my head i could read which fuse is which!im still going to drive home tonight and freeze! : :rockon:
Old Nov 7, 2003 | 12:15 PM
Vader's Avatar
Import guys? With no clue? Not surprised, are you?
Since the blower doesn't even work on HIGH, you might be able to disregard the fuse. Check for power at teh fan relay and fan motor connector itself.
This might help, but you'll have to provide the voltmeter:
Old Nov 7, 2003 | 12:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The blower won't work on High with a blown fuse either, because the power to operate the relay comes from the fuse.
Does the A/C compressor work?
If it also doesn't come on, and the A/C fuse is good, try taking the A/C control head out of the dash, and following the brown wire that comes from the "mode" switch, which is the one that's on the selector lever, and goes back into the dash. About a foot or so from the control head you will find a connector of extremely stupid design. If you attempt to unplug it, you will find that it's burnt to ashes. Cut both halves of it off, and replace it with a LARGE HEAVY-DUTY pair of slide terminals. Don't use the regular little weenie ones, because they'll just burn up too like the factory one did.
I've had to repair 4 cars just in my own family that deveoped this problem; my 83, one of my brothers' 84 Z28, another brother's 87 Monte Carlo SS, and my mother's Celebrity. I'd say it's a pretty common problem.
Old Nov 7, 2003 | 02:20 PM
adrienne's Avatar
Engine: v8
heat in the firebird
:hail: wow!!!You are GREAT!!!Can I add you to my buddy list... really, I will look at this in the AM.
Thank You!!!:yourock:
Old Nov 7, 2003 | 02:33 PM
adrienne's Avatar
Engine: v8
[QUOTE]Originally posted by RB83L69
[B]The blower won't work on High with a blown fuse either, because the power to operate the relay comes from the fuse.
Oh my gosh! I will take this advice and go look at my car tomorrow and see if I can follow directions!
THANK YOU!! for taking the time to leave a reply for me!!!
Old Nov 7, 2003 | 03:37 PM
Vader's Avatar
As usual, RB is correct. The blower gets its control power from the HTR/AC fuse as well:
Old Nov 18, 2003 | 06:44 PM
adrienne's Avatar
Engine: v8
heater for firebird
Vadar and everyone who took the time to send a rply to the rookie....
:yourock: :yourock: :yourock:
I have heat a fan and my car is not overheating either!!!!
Your the best!!!
Thank you!
Adrienne
Old Dec 17, 2003 | 07:59 AM
Jeff Morgan's Avatar
Guys,
Got a real loud (high pitched) noise coming from my blower fan for heater. Is blower motor gone? If so, is it easy to replace, and reasonable?
82 Pontiac Firebird S/E 305
Thanks for your help.
Jeff Morgan
Old Dec 17, 2003 | 01:32 PM
adrienne's Avatar
Engine: v8
heater fan
the info that vadar and others gave me was great and it did not cost alot to fix.
adrienne
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
krisner89
Oct 10, 2015 06:03 AM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
