What is the highest lift cam and spring safe for press in studs?
Old Nov 9, 2003 | 04:55 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Ok guys, I did a search and found mixed opinions.
I want to replace the cam and springs on my stock L98 (which is carbed now so no worry about the computer).
What would be the max lift you guys would think is safe with the press in rocker studs? Using 1.5 rr's or stock rockers.
What about springs? I will be using stock 1.250 dia springs. Would spring rated up to .550 lift be ok, or should I stay closer to .510 ?
Old Nov 9, 2003 | 05:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I would not recommend running any 1.25" spring past .500", no matter what the spring vendor claims; unless they offer you a warranty on your cam (which they don't).
Old Nov 9, 2003 | 06:14 PM
ede's Avatar
ede
.475 or so is my limit
Old Nov 9, 2003 | 06:24 PM
87transam5.7tpi's Avatar
i ran a LT4 hot cam .510 lift with stock L98 heads but i pinned the studs in. never had any problems. But you just never know.........
Old Nov 9, 2003 | 09:05 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i had a stock lg4 pull a rocker stud. anything i build from here on out is going to have screw-in studs.
probably a little overkill, but it makes me feel better.
Old Nov 9, 2003 | 09:37 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I may end up pulling the heads anyway and just go with bigger springs and screw in studs.
I was just thinking about just a mild cam bigger than stock though.
What is the specs on the stock 92 L98 cam? what kind of lift does it have?
Also, since I am carbed now, would a 110 lobe seperation be best to run?
deracer
Apr 11, 2016 12:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
