Spark Problem???
Old Dec 12, 2000 | 08:43 PM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
Spark Problem???
After driving my car for a few minutes, just when it gets to operating temperature, it dies like someone put out the fire, and will backfire throught the exhaust badly. Once it cooled down, I could drive it fine. I was thinking that it must have gotten out of time somehow, wrong answer, it is just right. It has gradually gotten worse, to the point where it will not start at all, and just gives me a little blurble every once in while. I pulled one of the plug wires off today, while my buddy cranked it over, the spark seem somewhat weak and did not fire every time. Some one told me the magnetic pick-up probably went(4pin HEI). I guess it really almost has to be that, since everything else is new. From the Dist cap to the MSD box. Any help would be great, I have stuck to much time and effort into this car for it to sit. TIA
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...
Old Dec 13, 2000 | 05:28 PM
ede's Avatar
ede
replace the module inside the distributor
ICON Motorsports
1st & 3rd
Old Dec 14, 2000 | 01:59 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Yeah, sounds like the module. But get it tested at a parts store before you buy a new one because a decent module costs around 50 bux.
Old Dec 14, 2000 | 04:44 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Make sure you have correct voltage going to the coil. I am not exactly sure, but you should have at least 4amps behind the 12-14 volts.
Old Dec 17, 2000 | 08:28 PM
BOWTIROC's Avatar
The module is replaced with the MSD box on a 4 pin HEI setup. Any other Ideas?
BOWTIROC's Avatar
TTT
Old Dec 17, 2000 | 10:30 PM
1983Z28's Avatar
Car: 83 Z28
Engine: 355 SBC
Transmission: TH400
Axle/Gears: 3.70
What condition are your spark plug wires in? I have had a similar problem and it turned out that the wires needed to be replaced.
Old Dec 19, 2000 | 12:12 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Take the MSD box back off and see if that solves the problem. Even if it doesn't, you'll have one less component to suspect.
mddaniel
Sep 8, 2015 05:16 PM
db057
Sep 4, 2015 07:57 AM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
