Very strange no-start issue.
Old Nov 13, 2003 | 03:52 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Ok, my car has no power whatsoever. I turn the key and nothing starts. No fuel to the pump, no guages, no lights...etc. Absolutuly nothing.
Everything seemed normal at first. I turned my alarm off and went to start my car. I heard the first click and then nothing at all. My alarm doesn't even work anymore.
I have ~12.6 volts in my battery right now. ~12.6 to the ground on the block, and ~12.6 to the alternator. So this is what is completely confusing me now. What could it be? Is there some sort of master fuse that I blew? if there is, where would it be located?
If I hook jumper cables together, I can make them spark. If I take the negative lead off of the battery, and tap it, I don't get any spark. I am confused. What the heck is going on?
Old Nov 13, 2003 | 05:30 PM
Catalingus's Avatar
Car: '59 Catalina 4 door
Engine: Cheby 350
Transmission: TH350
Maybe it's you ignition switch. You know the rod that is connected to your ignition lock. As it runs down your steering column there is actual switch there. If you take out two bolts that hold your steering column to the dash you'll be able to see that switch. It's on the upper right side of the column. Get a test light and check it out. It's a very cheap and easy fix. Have fun
Old Nov 13, 2003 | 05:40 PM
Sonar_un's Avatar
Car: '86 T/A
though, that would make some sense, but here is the wierd part. My keyless alarm system doesn't work either. That really doesn't have anything to do with the ignition switch.
Old Nov 13, 2003 | 06:32 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I suggest you take a look down at the starter where the car pulls it's power from the positive side of the battery.
The starter connection could be loose or you may have fried the fusible link there.
Old Nov 13, 2003 | 07:49 PM
Sonar_un's Avatar
Car: '86 T/A
That sounds like a very logical solution..
I will have to take a look at it.. unfortunately, its stuck at my work overnight... damn.
Old Nov 13, 2003 | 08:28 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Re: Very strange no-start issue.
Do your headlights work?? Brake lights work??? You said "no lights".... I just wanted to know what lights your talking about...
Dan
Old Nov 13, 2003 | 09:02 PM
Sonar_un's Avatar
Car: '86 T/A
No headlights, or brake lights. No guage lights. Guages don't start. No interior dome lights, nothing. Everything that goes to the fuse block is out. Including my power seats and cigarette lighter which doesn't require the ignition to be turned on to function.
Old Nov 13, 2003 | 09:26 PM
This REALLY sounds like a MAJOR connection problem somewhere...... Granted you're getting 12 volts to A LOT of places but make sure you're making good connections at the battery and to the block.
Dan
Old Nov 13, 2003 | 09:41 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
I had a problem just like this with my Firebird, only mine went down wile driving.
check the fuseable links at the starter like rustydawg said. that is what turned out to be my problem.
the easy way to check them is to pull on the wire. if one pulls apart then it is bad.
Old Nov 13, 2003 | 10:06 PM
Sonar_un's Avatar
Car: '86 T/A
Yeah, thats what it has to be, a fusable link. Its going to suck fixing this in the driveway at work
Old Nov 13, 2003 | 10:11 PM
but wouldnt he still have brake lights, headlights, and a dome light IF that fusable link burnt up????????
Dan
Old Nov 14, 2003 | 07:54 AM
Car: 91 Camaro RS
Engine: 305 LO3
Dan
when my fuseable link burned up nothing on my car worked. every thing just shut down. no lights, no door chime, nothing.
Old Nov 14, 2003 | 08:08 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Right when the fuseable link goes you will have no lights, buzzers, nada.
Old Nov 14, 2003 | 01:47 PM
I never knew that...thanks for the info.
IF that fusiable link DID break then Sonar_un is gonna HAVE to find out WHY that it burnt up.
Dan
Old Nov 14, 2003 | 02:53 PM
Sonar_un's Avatar
Car: '86 T/A
Well, it wasn't a fusable link guys. Turns out it was corrosion. I took everything apart (in my work driveway) and looked at the fusables, they were fine. I cleaned up the contacts with some steel wool and then checked the voltage. Seemed fine. Before the voltage was 5v or so at the starter.
Put everything back together and it started right up. Unfortunately now there is some real nasty hesitiation. I don't know why either.
Old Nov 14, 2003 | 09:11 PM
Car: 91 Camaro RS
Engine: 305 LO3
why do we not think of the simple stuff first
any way glad to hear you figured out what it was. but keep an eye on the wire that was corroded, it could easly have problems again.
Old Nov 14, 2003 | 11:09 PM
Dan
I think my orginal post stated the "simple stuff..."
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
Lmancha96
Sep 25, 2015 08:11 PM
RedLeader289
Sep 23, 2015 06:50 AM
BWilcox
Sep 20, 2015 12:19 PM
