400 roller cam install
Old Nov 15, 2003 | 08:48 AM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i've researched this and want to clarify this in my mind. all i need to install a roller cam in my 400 is the cam button to keep the cam from walking forward? and the retrofit lifters and custom pushrods?do i need that retaining plate on the front of my block?
Old Nov 15, 2003 | 12:25 PM
85TransAm406's Avatar
Car: 1985 Trans Am
no retaining plate, just a button. And either get rid of the stamped steel cover (if you have one) or get a water pump with an adjustable cam stop.
Old Nov 15, 2003 | 01:21 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The Milidon reenforced timing cover is really nice and only about $30-some bucks through Summit. It is built from much thicker steel than a factory one right from the start and has an additional plate of steel welded to the inside of it to absorb and spread the load from the button.
HTH
Old Nov 16, 2003 | 03:02 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
You will need a cam button, crane has one for about 10 bucks, you will also need the bronze spacer that goes between the cam and the block. you will have to use a retro fit roller cam and will require different pushrods. Thats why i did with my 406. Oh and you have to get a melonized distributer gear from GM.
Old Nov 16, 2003 | 06:59 AM
ede's Avatar
ede
with a billet cam you'd need a bronze distributor gear, not sure what a mellonized gear is, it may work. see it posted here a lot but never used one. the push rods aren't really custom, unless you need a odd length, you should be able to buy them from stock, just not stock length
Old Nov 16, 2003 | 10:58 AM
LilJayV10's Avatar
Engine: 406 Roller
you have to use a melonized gear when you are using a steel cam, thats what comp cams retro fit cams are. A bronze gear won't last a month on a steel cam. And you have to buy new pushrods, the best thing to do is to get an adjustable pushrod length checker. Comp cams recomended a 7.3 length pushrod for my application, and then i had .100 longer valves, so i was assuming a 7.4 inch pushrod, well i got a checker and i ended up needing a 7.2in instead. if you don't get the right lenth you will wipe out the valve guides.
Old Nov 16, 2003 | 01:25 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Check this thread, its almost the same click here
Old Nov 17, 2003 | 04:46 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Here's a good link with some stuff others might not have mentioned.
http://www.chevyhiperformance.com/te...ler/index.html
I suggest an aluminum timing cover. They can be had all day from eBay for about $30. Like this.....
http://cgi.ebay.com/ebaymotors/ws/eB...category=33625
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
