Double hump head
Old Dec 22, 2000 | 12:34 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
Double hump head
Does any one have a picture of the end of a head showing the double hump casting mark. I am at a loss on what I am looking at.
John
82 Firebird,355,Cam 224/234, .466/.488,TH350 Tranny,650 HolleyDP,Hooker Headers(I.E. POS) Manual steering
Best 8th et 8.62@80mph.
NEW for 01
Holley street dominator intake w3/4 in spacer, And a big hole in the hood.
Old Dec 22, 2000 | 02:29 AM
86_327_camaro's Avatar
i have a couple of sets in my basement. if i can get a pic and get it scanned i'll post 'em. its basically a rectangle with a half circle on either end.
/\_____/\
to be crude kind of like that except w/o the peaks. imagine half-circles in place of those. double humps come with and without accessory holes.
in my opinion they are good heads but it is almost to the point now with older chevrolet heads you have to spend a good bit of money to have all of the work done to them to have a good set of heads. its almost worth saving your money and getting a set of dart iron eagles or another aftermarket cast iron head.
Old Dec 22, 2000 | 04:33 AM
Pat Hall's Avatar
Hey Spud, post the casting # and I can tell you if it's a camel back head, or also commonly called the "fuelie" head.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Dec 22, 2000 | 07:07 AM
spud's Avatar
Engine: 400 & 355
Pat
I don't think they are, because they are 305 heads, but any way the casting # is 354434.
John
Old Dec 22, 2000 | 09:32 AM
Basett Racing's Avatar
The most common double hump casting #'s are (I'm using the last 3 digits) 186,492,461,and 492- there are others, but I'm listing the most common. The 186,492 have accessory bolt holes in the the front of the head like modern heads do. Some of these more desirable ones are 461X,292(angle plug), and 370 (angle or straight plug)all these heads have slightly bigger intake runners. The 292 and 370 have accessory holes as well.Another head that is a 64cc comb chamber, comparable runner head is an 041 -- these perform as good as a double hump. The casting mark on a double hump looks like two half circles, located directly in the front of the head. The 041 has a triangle that points to the exhaust side, unlike the 882 and some 305 heads that point towards the intake. Hope this helps
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
http://www.bassettracing.cz28.com
Old Dec 22, 2000 | 04:30 PM
Pat Hall's Avatar
Enough said Spud. They never made a fuelie head for the 305, so I guess your question is answered! To the guy from Basset racing: I have another casting # to add to the list. I have two sets of fuelie heads that are casting # 462. They're almost identical to the 461 castings. They're the early style with no accesory holes, and the sets I have are dated around '66.
Old Dec 22, 2000 | 09:04 PM
Thanx, Pat. I missed that one. I actually have a set of those(462's), 461's, and a set of 041's. My 462's are dated 66 also, my 461's are dated 64, and my 041's are dated 69. I recently sold a set of 186's, dated 70.
Old Dec 22, 2000 | 09:40 PM
spud's Avatar
Engine: 400 & 355
John
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gixxer92
Sep 1, 2015 04:32 PM
TreDeClaw
Aug 14, 2015 06:58 PM
