I'd like to not freeze if at all possible
Old Dec 22, 2000 | 09:50 AM
Yarnboy's Avatar
Is there anyway to get more heat? When the high temperature is a max of 28 all day and it's 13 at night..I'd like a little more heat than the pathetic amount that blows on my feat. That sound like a Chtismas poem..weird..Anyway, do they make like aftermarket blowers or anything? I guess with no SES light I don't have much to complain about anymore..thanks
-Red '88 IROC 5 Speed 305 TPI w/3.08
-Dual Friction Centerforce Clutch
-Accel 300+ Racing Ignition
-Accel 300+ Pro Sleeve Plug Wires
-Accel U-Groove Plugs
-Flowmaster Force II 3 Chamber Cat Back Exhaust
-Hypertech Chip
-Hypertech Airfoil
-Removed, Then Re-installed (out of fear) MAF Screens
-Gutted Air Box
-Best E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 MPH 93.91
-Best 60' 2.17
Old Dec 22, 2000 | 10:09 AM
craig90formula's Avatar
What temp thermostat are you running? I had a 160, and my heat sucked. Switched to a 180, and now I can stay toasty warm!!
Old Dec 22, 2000 | 10:34 AM
jrr's Avatar
jrr
Put your A/C into MAX. There's a small door to make the system recirculate the interior air. Look under the passenger's side where the air comes back in and see if there's any leaves, dust, bugs, etc. clogging things up.
Clean that stuff out and that should help move more air.
If the motor's simply not getting hot enough and the heater core is O.K., go down to the hardware store and get a sheet of pegboard. Cut it to fit in front of the radiator. Those holes will allow a uniform flow of air to the radiator but reduce it in order to get the coolant temperature up where it ought to be. You can always drill bigger holes or remove a section if the motor gets too hot.
Old Dec 23, 2000 | 04:46 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Good thinking JRR. Big rigs do the same thing. Blocking off the radiator can also make the engine run better and also reduce emissions.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
cking99
Sep 22, 2015 11:33 AM
Stryker412
Sep 20, 2015 06:59 PM
KamaroZ350
Dec 27, 2011 11:03 PM
Macgyver
Aug 12, 2001 04:37 PM
