timing problem
Old Nov 19, 2003 | 12:28 PM
83t-top's Avatar
timing problem
hey fellas! just put a new 383 in my 83 trans am. whenever i try to set the timing it goes crazy. i set the timing at 12 degrees atdc with the vacume closed. when i connect the vacume back to the timed port the engine races up to around 16 degrees. anyone had this problem before? btw its a stock gm hei with msd 6al. thanks for any imput.
Old Nov 19, 2003 | 04:57 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Uh, i am hoping that was just a typo, and you REALLY meant btdc. Having the timing change when you hook up the vacuum advance is normal. No worries. So long as the engine runs good, you are in fine shape. Have fun now.....
Old Nov 19, 2003 | 05:52 PM
83t-top's Avatar
my bad. i was kinda in a hurry. btdc is what i meant to type. it runs fine except for the rpms going from 750 to 1200. im stumped!
Old Nov 20, 2003 | 01:09 PM
83t-top's Avatar
has anyone had this problem? please, i need help!
Old Nov 20, 2003 | 02:41 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
idle rising when the timing is increased is normal. You may want to readjust your idle.
Another thing is that you might be using the wrong vacuum port.
Old Nov 20, 2003 | 03:46 PM
83t-top's Avatar
ive got the vaccume on the left port on an eddy. i think thats the timed one. also i cant idle the carb any lower. still lost on this one. the dist. didnt always do this. could there be something wrong inside the dist?
Old Nov 20, 2003 | 05:50 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
check to see if you have a leak in your vac advance cansiter. Sometimes the diaphram ruptures or dry rots.
Old Nov 20, 2003 | 06:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Driver's side? That's full-time vacuum.
Old Nov 20, 2003 | 09:57 PM
83t-top's Avatar
PASSENGER SIDE. LEFT LOOKING DIRECTLY AT THE CARB. SORRY
Old Nov 21, 2003 | 11:01 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, that would be the right side of the carb.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
