how do u reset the ecm?
Old Nov 20, 2003 | 02:22 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
do u just disconect the battery for 5min? thnks
Old Nov 20, 2003 | 03:07 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
i disconect mine for 15 just to be sure
Old Nov 20, 2003 | 03:54 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Only about 5-10 seconds here.
Old Nov 21, 2003 | 09:22 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Few minutes should take care of it.
Only down side is you lose all your radio staions...
Old Nov 24, 2003 | 10:10 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Cool thnks guys
Old Nov 24, 2003 | 01:16 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
There is a small connector coming off the positive bat cable that is connected to the ECM. If you disconnect that for 30 seconds it will reset the ECM. That way you don't have to diconnect the Battery cable and loose everything.
Old Nov 25, 2003 | 10:54 AM
SHAGME's Avatar
Car: 1988 IROC-Z
oh cool thnks Ill remember that one dam radio stations. lol
Old Nov 25, 2003 | 10:10 PM
84camaro350's Avatar
easiest way without losing all the rado settings it to take your underdash panel on passenger side off (like 4 screws) and disconnect the ecm harness, 5 minutes is more than sufficient the ecm is "supposed" to reset after 30 seconds, but 5 minutes will ensure it is reset, and by disconnecting the harness you will not lose any presets and wont have to screw with the battery.
Old Nov 26, 2003 | 07:31 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Attached note is the easiest way to reset the ECM. 2 seconds max... Unless later models (mine is '83) do not have a connector coming off the Battery connection.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Ed1LE
Sep 30, 2018 09:14 AM
okfoz
Oct 13, 2015 02:19 PM
Jlanz55
Sep 29, 2015 08:55 AM
