What is the easiest \ best way to pull an engine???
Old Nov 25, 2003 | 02:10 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
This thanksgiving break I am going to pull out my old engine, I was wondering whats the easiest way to do it?
Should I strip the engine down to the short block then pull it or leave the heads on? Should I pull out the engine with the transmission attached or disconnected? If I pull the engine with the transmission attached do I have to take out the radiator for clearance?
Old Nov 25, 2003 | 04:01 AM
MizfitCreations's Avatar
Car: 87 Camaro LT
Engine: ZZ4, AFR195, XR276-HR
Transmission: 700R4, Transgo
I wooudl take out the radiator either way so you don't accidently hit it, doesn't take that long to take out anyways since you have to drain the fluids already.
Make sure you take the Distributer off or it will hit the firewall. The headers might catch so either take them out or unbolt them. I usually take it out with the manifold and heads still on.
As for the tranny, do you need to take it out? do you feel like tryin to unbolt those 2 top bolts out ( always found to be a pain)
Old Nov 25, 2003 | 04:36 AM
ede's Avatar
ede
not very pratical most of the time but if you invert the car the engine will usually fall right out, so i guess that's the best method as far as amount of effort required.
i always pull engine with trans attached if it's an auto, manuals depend, i strip the carb/tbi/tpi and distributor and sometimes whatever is bolted to the front. removing the radiator is a good move.
Old Nov 25, 2003 | 05:13 AM
EvilCartman's Avatar
Car: '82 Z28
Here's how my 305 came out...
Old Nov 25, 2003 | 07:20 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If you don't need to remove the tranny, pull the engine only. It takes a little finese to get the engine/trans out together, but it can be done. I strip the dist, water pump & carb (if equipped). I would pull the rad too. It sucks when the engine accidentlly crashes into it, causing unrepairable damage.
Old Nov 25, 2003 | 03:21 PM
Firl's Avatar
To make it easier on me what I usually do is leave the intake on and everything and tie a chain to the engine via the clips that go into the intake, and I remove the headers/exhaust manifolds. Its easier for me to drop the tranny/engine in together so that I can make sure that the tranny goes on right instead of getting under the car making sure the torque converter is on right.
But if you can get the tranny disconnected easily, would save you time from disconnecting it from the cross member/the universal joint.
Old Nov 25, 2003 | 03:50 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
No need to remove the distributor... just take off the cap and wires and you'll be fine, just like when mine came out. You can leave just about the whole engine assembled. I think all that came off mine when it came out was the dist. cap and the exhaust manifolds.
The rad is a good idea to take out as well.
If its a early manual trans, dont forget to disconect the Z-bar too, lol... it wont wanna come out if you leave it.
Old Nov 25, 2003 | 04:45 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
and for sure dont take your headers off like stated above...
thats just silly, you'll have plenty of room to move the engine to avoid them hitting something, if they do at all
(pulled my 355 out twice with headers, never even had to worry about it.) dont risk snapping a bolt/stud...
once u have it out, if your going to take them off then i would soak them in penitrating oil/wd 40...
Old Nov 25, 2003 | 09:27 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I would drain & remove the radiator,,
drain the tranny,,
drop the drive shaft,,
disconnect everything going to the engine and tranny,,
remove at least the distributor cap if not the whole thing,,
put a small hydraulic jack under the back end of the tranny,,
pull the engine & tranny together.
As you pull the engine out and forward a bit, you will be lifting also,,, the tranny will ride on the jack as the whole thing comes out. Have the wheels of the jack and jack wheels in line with the tranny.
Having the tranny with the engine will pay dividends when it comes to put it all back in.
BTW: It is alot of hard work no matter which way you do it. Just be prepared.
Old Nov 25, 2003 | 09:45 PM
Firl's Avatar
I pull my headers because they ride close to the firewall and don't want to risk hurting anything ::shrug::
Old Nov 25, 2003 | 09:51 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I knew that I forgot something important.
Being as I am (very forgetful), I would strongly recommend that you label everything that you remove as far as the connectors are concerned. Also, put bolts in marked plastic bags. And also, take alot of pictures.
Hope this helps and good luck!
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
dutch930
Sep 11, 2015 06:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
