is there a sensor that is suppose to do this?
Old Dec 27, 2000 | 06:42 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
That is suppose give the car a little gas or kick it up upon decell? If so where is it? And if not are there any that kick up the idle for anyreason? if so where Thanks alot 86 Lg4
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Dec 27, 2000 | 10:29 AM
Blade's Avatar
The only "sensor" that does that is the solenoid that moves the throtle up when the A/C is on. Maybe you can try to activate that with a vaccuum activated switch or something ? lol
Old Dec 27, 2000 | 10:33 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
ROFLMAO...no further comment
Old Dec 27, 2000 | 05:17 PM
BLACK Z's Avatar
Car: 86 Z28
So what does the fast ilde relay Do?
Old Dec 27, 2000 | 08:10 PM
Damon's Avatar
The A/C compensator jsut raises the idle a few hundred to compensate for the load of the A/C compressor. It's basically an on/off type of solenoid.
There were some QJet applications that used a more sophisticated idle speed solenoid that could actually set idle RPM according to what the ECM called for, but I don't beleive the Camaro (or any Chevy) ever employed this type of system.
Old Dec 27, 2000 | 09:16 PM
Vader's Avatar
BZ,
Since you have a manual transmission, you need to install a dashpot on the throttle linkage belcrank to allow the throttle to come to rest in the idle position a little more slowly. These can be had at a good auto parts house for about ten bucks.
Ed,
You can stop rolling on the floor now...since I AM old enough to have used a few of those.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 28, 2000 | 06:38 AM
BLACK Z's Avatar
Car: 86 Z28
The relay I am talking about is on the firewall next to the map sensor, the one you guys are talking about is on the carb correct? Is that one adjustable? thanks
Old Dec 28, 2000 | 09:55 AM
Blade's Avatar
Relays are not adjustable. They either turn on or off. In case you haven't noticed we're all having some serious fun here... I would drop this if I were you and figure out your carb problem (if it makes you think it shouldn't do whatever you think it does wrong).
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Dec 29, 2000 | 08:26 AM
Ed Maher's Avatar
Car: 04 GTO
Unfortunately vader, i just can't stop laughing. You see, i know exactly what problem he is trying to fix and a dashpot isn't the answer. You sound like you are describing an anti stall dashpot, which lets the throttle close a little more slowly if you get out of it real fast, something which really makes carbs mad. He's trying to find a fix for afterfire when he's engine braking.
Alas, my best idea, using the relay themes presented here would be to use an rpm switch and some type of TPS trigger so that under certain high rpm/closed throttle conditions you hit the AC compensator solenoid to crack the throttle a little more. Of course i highly don't advocate trying this, more throttle when you are trying to slow down just doesn't seem like a good idea. Then again, making a convenient way to trigger off a closed throttle TPS is a chore enough in itself, unless you really cheat and use a microswitch (like for nitrous.)
Anyhow, i'm gonna fall off my chair again...good luck...ed
92firebirdguy
Sep 1, 2016 07:53 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Eric-86sc
Sep 7, 2015 02:10 PM
