wobbling steering wheel!!!!! NEED HELP
Old Dec 3, 2003 | 07:51 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
ok i have an 89 Iroc-Z w/ stock steering wheel and tilt.
if you put your hands on the top and the bottom of the steering wheel. it rocks back and forth. The "tilt" still works and the wobbling only happens in the up and down direction, not side to side.(if your sitting inthe drivers seat, like drivingthe car)
Does anybody know what holds the steering column in place and have any pictures of there steering column out of the car. Any pictures or diagrams would greatly help me to figure what is wrong with my steering wheel. I don't feel completely safe w/ a wobbling steering wheel.
If this is in the wrong area, please move it to the proper area.
Thank yuo
Jonathan AKA WyClef
Old Dec 3, 2003 | 08:17 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I don't have pictures, but I've fixed the tilt column issue.
There are several posts on this already. Below is probably the BEST post regarding this issue.
https://www.thirdgen.org/techbb2/sho...highlight=tilt
Essentially you have to tighten 4 torx bolts at the base of the column.
You will need a steering wheel puller, and a few other goodies. You can probably rent most of them from Autozone if you don't have them already.
Old Dec 4, 2003 | 05:06 AM
ede's Avatar
ede
sounds like the bolts are loose at the tilt joint. 3 torx head bolts are all you need to tighten. i think there's a tech artical on the main page. if you have to buy a socket buy a deep one, it'll give you a lot more access to the bolts. mine cost around 10 dollars from snap on.
Old Dec 4, 2003 | 09:40 AM
Vader's Avatar
wyclef,
At the top of this page is a very powerful feature of this board. Look for the button, and think of it as an all-powerful tool to find answers.
"Use the Force, Luke..."
Old Dec 4, 2003 | 04:27 PM
Engine: peanut LB9
vader
I did try the search button but didn't find what i was looking for. but thanks to FruityOne, I found what i was looking for. thanks FruityOne and ede.
WyClef
Old Dec 7, 2003 | 03:22 PM
Vader's Avatar
You should be able to find everything you need at these links:
https://www.thirdgen.org/techbb2/sho...hreadid=140910
http://216.121.161.76/files/SteerColumn1.pdf
http://216.121.161.76/files/SteerColumn2.pdf
Old Dec 7, 2003 | 04:28 PM
Engine: peanut LB9
thanks vader, i only have three problems as of right now.
1- that long rod that goes from th bottom of the column to the top by thehigh beam linkage. i don't exactly know how that gets linked up
2- the piece that goes under the turn single switch ***. that little white piece w/ 2 copper piece hanging out. i broke one of those pieces of copper.
3-I'm not 100% sure on how the bearing go back into place on the steering shaft.
Old Dec 8, 2003 | 08:26 PM
Engine: peanut LB9
ok I've fixed both my first and 2nd problem now i have the problems with my bearings.
83 Crossfire TA
Jan 3, 2016 01:26 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
