Temp Sensor for AFR heads
Old Dec 4, 2003 | 01:58 PM
Torque91's Avatar
AFR had an option for drilling a hole for a temp sensor I have a 91 TPI do i need this or not?
Old Dec 4, 2003 | 03:11 PM
Marc 85Z28's Avatar
Yes, it is for the ECT (engine coolant temperature) for the ECM. Sucks that they charge extra
Old Dec 5, 2003 | 06:35 AM
Torque91's Avatar
I thought my engine coolant temp was up on the front of my intake manifold?
Old Dec 5, 2003 | 06:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You don't need them, as long as you can do without your temp gauge and your fan switch.
Just get them installed. If you find you don't need them, put pipe plugs in them. It's one hell of alot cheaper to get them put in now than to be standing next to an assembled car except for one last part, staring at an undrilled boss, and realizing that you now have to take it all apart and send the heads out to get done what should have been done at the factory.
Old Dec 5, 2003 | 06:41 AM
Torque91's Avatar
ya I guess whats $25 more bucks when I'm already paying so much. Thanks.
Old Dec 5, 2003 | 06:49 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, common sense.... it seems kind of stupid for AFR to even offer the option of leaving the holes out, considering that just about everybody will need them, even for a strip-only car. But then they do several things about their product that strike me as stupid; great castings, but the finished product is less than it should be.
Old Dec 5, 2003 | 09:10 AM
Torque91's Avatar
Wow I called AFR this mourning to add the temp sensor hole to my heads and the sales rep told me about a month ago they started including that hole on every head so mine already was drilled for the temp sensor. Just thought u guys might like to know.
Old Dec 5, 2003 | 09:22 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Didn't need holes in my application. There were 3 holes in my HSR manifold, one for heater hose, one for the gauge sensor & one for the computer, no need for one in the head.
Old Dec 5, 2003 | 03:06 PM
demonchild's Avatar
there are other places that you can route that temperature sensor. i believe you can get a thermo housing with as many as three holes for different applications.
Old Dec 6, 2003 | 08:42 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i just ordered my AFRs on monday and the rep told me that the holes are already there.
Old Dec 6, 2003 | 08:47 AM
EvilCartman's Avatar
Car: '82 Z28
Yup, they were in mine already too and I ordered them a few months ago.
evilstuie
Jan 9, 2020 08:29 PM
CRFred
Feb 7, 2016 11:39 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
