How to removed hood and hatch struts
Old Dec 7, 2003 | 10:47 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Hey I need a quick reply on how to remove the hood and hatch struts.
ty
Old Dec 8, 2003 | 04:39 AM
ede's Avatar
ede
struts have a little clip or bolt on the ends. hood has bolts on the hinge.
Old Dec 8, 2003 | 05:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Prop the hood with a stick; remove the clips and replace the strut, ONE AT A TIME.
Same for the hatch struts. Except, the hood only weighs about 40 or 50 lbs; the hatch weighs a couple of hundred. Don't forget to remove the electric connectors for hatch defog if your car has that. Make sure you prop it up with something substantial. Hint: PVC pipe is inadequate.
Old Dec 8, 2003 | 12:09 PM
Vader's Avatar
Do we dare ask how you might know that PVC pipe is inadequate? There's probably a story there somewhere... an expensive story.
As for those ground connections for the defroster and third brake light ('86 models), make sure you orient the connectors on the struts to prevent strain on the wires from opening and closing the hatch. If the wires are strained, they will pull off, making your hatch-mounted devices inoperative. On an '86, if the grounds are loose, the rear defogger will turn on whenever the brakes are applied. That can be a little confusing and disconcerting if you don't understand the circuit grounding.
Old Dec 8, 2003 | 12:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Fortunately, not expensive; but it was painful.
Old Dec 8, 2003 | 02:50 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Why would I remove the connections for the rear hatch defroster if I'm replacing the struts?
Old Dec 8, 2003 | 02:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you had one you'd know.
Old Dec 8, 2003 | 02:57 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
well, I have one but never looked at it. I'll go do that right now.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
3rdgenparts
Aug 8, 2015 07:09 PM
