help installing clutch slave cylinder please.
Old Dec 12, 2003 | 12:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I broke my slave cylinder for my clutch, and i bought a replacmeent, i know where it goes but ive never done a install before, can i get some tips? i have this pin and round thing i dont know what it does.
Old Dec 12, 2003 | 12:46 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i got the slave cylinder disconnected but i cant get the hose off of the cylinder. does it pull out or does it screw in? or w hat? thanks!
Old Dec 12, 2003 | 12:54 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
If I recall right, there is a small roll pin that needs to be driven out, then the hose just pulls out. Clean the collar where the hose connects to the slave, and look for a hole with a roll pin in it. Also, make sure you use a roll pin punch, not just a regular punch to remove it or you could do some damage.
Old Dec 12, 2003 | 12:55 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
oh ok i know of the pin you speak of. i dont think i have that tool though lol, is thier a more conventional way, i dont car if the slave cylinder breaks anymore then what it already is .
Old Dec 12, 2003 | 12:57 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Hi Traviz.
There should be a roll pin just below where the hose joins the cylinder. Sometimes difficult to see, since it is flush with the sides and normally covered in dirt. It will be quite tight, but tap it out, The new pin you mention should be the same as the one coming out.
Make sure the hose seal is in place in the new cylinder before the hose goes back in.
Very best of luck bleeding it out! You ay need it!
Andy.
Old Dec 12, 2003 | 01:25 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok thanks for the help, i got the pin out, i got the new cylinder all installed now. now my question is, do i now cut those pieces of plastic that held the tip of the cylinder? thanksm
Old Dec 12, 2003 | 04:49 PM
Car: 91 camaro rs
I did, and mine works fine. If you don't, they will break anyway the first time you press the pedal.
Andy.
Old Feb 24, 2009 | 10:49 PM
speedcrazy's Avatar
Car: 1984 Z28
Re: help installing clutch slave cylinder please.
Thanks so much. I was having this same problem trying to figure it out too because mine just busted. All of you are great help.
Old Feb 25, 2009 | 01:32 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
I think mine may need to be replaced, what did you end up paying for the replacement piece?
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
NinjaNife
Aug 23, 2015 11:49 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
