clutch problems
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
clutch problems
My TO bearing went bad so I had to replace it, while the tranny was off the vehicle, i was stupid and playing with the clutch pedal. it was extremely stiff, so i gave it some pressure and it gave in then it felt real lose after that. after i got everything back together, the clutch pedal felt the same still. I replaced the clutch slave cylinder and i think i bled the system correctly, but still the clutch pedal is dead. theirs no resistance , when i start the car and i push the pedal in, i still cant shift into any gears.
what did i break this time? thanks!
Car: 1985 Iroc-z
Engine: 355 sbc
you would probably get more replies on your problem if you would post in the correct board =]
how did u bled your system? did you connect the linkage/exam to see if you broke anything? and i think hydraulic clutches are self adjusted... plus you could have installed your throw out wrong... its common. can u see the fork moving when someone pushed the clutch?
i think you bled the slave cynlinder wrong or maybe the cynlinders are toasted.
post in the tranny board though
theshackle
Aug 31, 2015 10:47 AM
db057
Aug 11, 2015 10:11 PM
rsrmoore
Aug 7, 2015 08:44 PM
