1990 IROC-Z 5.7 engine#s?
Old Dec 15, 2003 | 12:59 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I recently aquired another 1990 IROC-Z It is a hardtop 5.7TPI. It has relatively high mileage. But while changing the oil I looked inside of the engine where the oil fill is and it is so clean it appears almost new. Crate motor?
The only numbers I could find today are V0920 (no VIN number) stamped on the engine block machined deck pad on the right front, and cyl head casting #s 14101083 with T140 below it.
Can anyone help out with these numers?
Old Dec 15, 2003 | 06:52 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
083 heads sounds right for a 350 TPI motor, and I think a crate engine would have nothing written into the machined pad above the pass. side water pump.
Old Jan 2, 2004 | 07:56 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Upon further detailed investigation I have found that the car does in fact have the original engine. It is a one owner car, and he sure must have taken very good care of it.
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 2, 2015 09:12 AM
usafirebird
Sep 29, 2015 11:58 PM
