Which roller timing chain?
Old Dec 17, 2003 | 05:24 AM
bigals87z28's Avatar
Car: Check The Sig
Im looking at the Comp Cams 3136 and the 2136. The 3136 says its a racing chain, and the 2136 is a street chain?
2136
Vendor: Competition Cams, Inc.
Product Line: Competition Cams Timing Chain Sets
Material: Cast Iron
Finish: Machined
Timing chain sets for every need.
Chevrolet: 1987-92 4.3L/5.0L/5.7L, Magnum Double Roller timing set
This Magnum series timing chain set is designed for your high performance street machine. Features like a pre-stretched large pin, double roller chain, thorough heat treat, and dynamic balance assure you're getting one of the best double roller designs on the market.
Sold individually.
3136
Material: Billet Steel
Finish: Machined
Chevrolet: 1987-90 5.0L/5.7L, with factory roller cam, Hi-Tech Roller Race, timing set
Comp Cams offers a complete line of timing chain sets, including this Hi Tech Roller Race timing set for extreme racing. It features a double roller chain, a triple index gear, oversized rollers, and a dynamic balance.
Sold individually.
Now, the "race" one is cheaper, but is there a major difference that Im not seeing? They are both for roller cams. Which should I go with?
Old Dec 17, 2003 | 05:31 AM
ede's Avatar
ede
what are you doing with it, street or race? that ought to help answer your question. actually i'd buy one from cloyes and not comp.
Old Dec 17, 2003 | 09:18 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I second the Cloyes recommendation..use their "True" roller.
Old Dec 17, 2003 | 04:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I got a Sealed Power double roller... pretty sweet.
Old Dec 17, 2003 | 07:04 PM
Guest
Guest
Posts: n/a
Instead of guessing, call them about it.
Old Dec 17, 2003 | 07:36 PM
Car: Check The Sig
then wtf is this site for?
Old Dec 17, 2003 | 07:44 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Why use the phone book when you can call directory assistance?
Old Dec 17, 2003 | 08:42 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Yo Al,
The one for race is made of billet steel. The street one is cast iron. I would go for the billet. The timing set I use is from an Aussie company, can't remember name. Its really nice. Billet upper gear with torrington bearing on the back side for smooth operation. Heat treated lower gear with 8 different keyways for cam timing changes. Not very practical for everyday tuning, but nice feature!! True roller chain of course. The best part is I got it from my local speed shop for $20 more than the top of the line Cloyes. No dis to Cloyes, they make a nice part too...
Old Dec 18, 2003 | 12:03 PM
Guest
Guest
Posts: n/a
Advice, and I gave mine.
Old Dec 18, 2003 | 03:01 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
Vintageracer
Jan 10, 2020 05:33 PM
junkcltr
Aug 2, 2019 11:12 PM
MY87LT
Aug 17, 2015 08:43 AM
BrianI
Aug 9, 2015 11:52 AM
