Corvette Heads On A 305?
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
I read in the camaro performance handbook, that Aluminum Corvette cylinder heads, casting number 10088113, are a good swap on a camaro 350. But will these work on a 305? The corvette heads have a 58cc cumbustion chamber and a 163cc intake runner volume. They also use standard 1.94 intake and 1.50 exaust valves.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i wanna know also, id liek to get a set for my 305 but the only thing i think is the problem is there is no EGR passeage so you wont be able to use your egr valve and they have the center bolt valve cover holes, other then that i dont know what other problems there are with them. id like to get a set instead of gettin a set of World product s/r torquer heads.
Originally posted by johnjm22
I thought the egr valve was on the intake manifold.
Transmission: 4L80E/4L80E
The effective compression will be lower than with iron 58cc chambers because of the heat loss through the aluminum heads. To gain back the power lost by going to aluminum, you'd have to shave the heads to reduce the chambers by about 6cc. Remember, L98 64cc iron heads equate to 58cc aluminum heads.
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
The corvette heads they are speaking about are the 58cc combustion chamber heads. 305 heads have a 58cc combustion chamber. As far as the power and compression losses, it may all wash out in the end. What I mean by this is, yes it is true that all things being equal, an iron head is more efficient than a aluminum head because of the thermal efficiency. An iron head retains more heat than an aluminum head thereby aiding in the combustion process, but may the ports on this aluminum head be more efficient than the iron head? It could all equal out. Just my 2 cents.
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
corvette heads on 305
I am in the big middle of this conversion right now.your main problems are going to be the header configuration.If you want to remain smog legal ie smog pump it really gets tough,because of angle plug and the D shaped exhaust port. Today I have been to my local speed shop and it is a tiugh match as in no shorty smog legal headers apparently exist for these heads.I have got over 600.00 in my 113 heads and cc to 55 cc per chamber and now upon further investigation headers are going to be a prob.SLP says that they do not have a header to fit this head (3 times) hooker no hedman maybe I can't get thru today.javascript:smilie('
javascript:smilie('
')javascript:smilie('
') Senior Member
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
thats strange.
i'd imagine any header that would fit those year vettes or ZZ4 would work?
I have hooker 2460's and 8113's. i haven't installed anything yet because i'm waiting until i have everything i need then knocking it out in a weekend...interesting.
Car: 1984 Z28
Engine: L69 305 HO
ZZ4 heads on 305
thats strange.
Yeah thats what I thought maybe 1a3/4 headers will work but SLP was very sure 3 times that they didn't have what I needed.So was hooker in the shorty models today. It would appear to me that long tubes present to much of a ground clearance prob.plus as I said earlier smog legal is for me a prob. the politicians in OK have dropped the state inspect for now but that leaves to much $$$$$ in my pocket for their wants and wishes.......
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i dont think i quite follow you...
are they saying the heads/headers won't match up?
i think i'm gonna have to go home and run out to my parts shed, get everything unpacked and bolt them up.
lol
maybe i'll take a few pics.
lol
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I've always heard that with slp thirdgen headers you HAD to use the l98 angle plug or straight plug heads, not a regular angle plug head.
Car: '91 Z28
Engine: 5.7 by Scoggin-Dickey
Transmission: auto
The bore size is different. The valves comes very close to the bore, the 1.94 comes mighty close, thats why the valves are so small on the 305. Also you will have a miss match of chamber dia, bore dia and head gaskets. There is am after market available that improves flow considerable, can't think of the name.
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
th problem is the exhaust ports on the 113 heads are raised 0.10"..so you need special headers....who makes them, i don't know!
ambainb
Apr 25, 2016 09:21 PM
