High Oil Pressure
Old Jan 9, 2001 | 04:49 AM
XxMoLexX's Avatar
High Oil Pressure
I have a 3.1 RS and the oil pressure is kinda ridiculous. I know that its supposed to be higher than most other cars.. or at least that wat it says in the book i have. BUt when im idling the needle basically just lays down at well over 80psi then it goes down to a respectable 40-50 when on the gas if i remember correctly.
I would say that the needle goes as far as possible with out actually laying down
Any ideas?
i heard somewhere to check some kinda oil pressure valve or.. sending switch ... i dont remember. If this is the case... Where is it?
Old Jan 9, 2001 | 05:21 PM
ede's Avatar
ede
it should be higest when you're in the throttle. more RPM = more oil preasure. i'd put a mechanical gauge on the engine and see what it says.
ICON Motorsports
1st & 3rd
Old Jan 9, 2001 | 05:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its the oil pressure sending unit, located just above the oil filter. It looks like a 35mm film canister, with a plug sticking out of it.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 9, 2001 | 06:18 PM
LottaBallsCamaro's Avatar
I agree with kevin91Z. Altough he didnt explain it very well. The sending unit tells your needle what to do. It has no effect on oil pressure.
91 Camaro RS, 305 TBI
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
Edelbrock MPFI system.
RAM air hood & Z28 wing.
Z28 cam.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
