Occasional irradic idle :confused: w/in..
Old Jan 7, 2001 | 09:19 PM
Stuart S's Avatar
The car is finally running! Rebuilt Q-jet and purge valve, changed oil (which was LOADED with gas - it reeked and looked like water..)
Drove it from MD to NY yesterday, averaging 23mpg
...anyways it's normal "comfortable" idle speed is around 750 rpm's in Park or Neutral...i think some sensor is telling the ECM to "bump or drop" the idle irradically - it ranges from 500-1500rpms on its own, but only sometimes - other times its fine at 750rpm. I reset the codes yesterday, and after a day of driving it I have no new codes. Any ideas? Thanks! (86 IROC LG4)
Old Jan 8, 2001 | 06:48 PM
Stuart S's Avatar
GEEZ! people post dumb crap like "whats the puddle on my passenger carpet and why don't I have heat" and THEIR posts get replies...
Thanks alot, really!
Old Jan 8, 2001 | 06:57 PM
Birmass's Avatar
Check O2 and MAP sensor... That's your problem I bet.
Did you check the timing. That could do it too?
The oil we drained filled up two 64 ounce bottles, a 2 liter bottle, and I still had about eight more ounces left over.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
Old Jan 9, 2001 | 09:23 PM
Stuart S's Avatar
ya know, this is sad...
you guys have about as much tech skills as a dead frog in a lake...thanks alot...
Old Jan 9, 2001 | 09:54 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Yo, Stuart, I symphatize with your frustration.
If I had a clue about working on your problem with the LG4 engine I'd have jumped in with both feet, but I don't. Sorry. Any suggestions I could make would be L98 based.
The last time a couple of us tried to help out with an LG4 problem "Blade" criticized us for being inaccurate. Something like "Don't put up a response unless you're at least 90% sure it's right", or words to that effect.
So I'm guessing that 'caution' is the watch-word now. This could be why responses have been so limited.
There's got to be an LG4 guru around here somewhere to help you out.
Hope you get it solved.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Jan 10, 2001 | 01:40 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Mine does the exact same thing very intermittently...it always throws code 34 (too much maf flow) when it does this and seems to do it more often in damp weather. I tried once to replace the maf relays, but pep boys kept telling me they didn't exist and instead of screaming at them i just left. i'll replace the relays soon and maybe that will help. mines an lb9 but maybe this helps
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Jan 10, 2001 | 02:44 AM
Ski89Z28's Avatar
Stuart, I'm in the same position as JakeJr but I had the same problem with my L98. It was a bad ignition control module in the distributor. I don't know if the LG4 has one but if it does it may be the problem.
Good Luck!
89 IROC 350 Auto
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears and a bad ignition control module!
And Free mods.
Old Jan 10, 2001 | 03:45 PM
Birmass's Avatar
Gee, thanks Stu for saying that I have no tech skills... Have you checked what I told you to?
88 firebird formula
350 Vortec TBI
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
My Formula
Old Jan 10, 2001 | 08:21 PM
Stuart S's Avatar
Not you, dork...and no, not yet...
Put a scanner on it today and am still getting a code for BARO and lean O2...oh well...thanks ppl.
gta892000
Aug 11, 2019 11:16 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
Blue419
Sep 10, 2015 01:03 PM
IROCtometal
Sep 9, 2015 10:01 AM
