TPI with Dual Fans,but only one working???
Old Dec 28, 2003 | 03:46 PM
TPI86TA's Avatar
Car: 88 GTA
Under the hood of my 88 GTA i have the dual electric radiator fan set up.I noticed when its time for the fans to kick on,only the fan closest to the driver side has been kicking on.The second fan hasnt been kicking on.I tested the second fan by touching the wires to the battery and i know the second fan is not broke.Now my question is,shouldnt both fans be kicking on at the same time,or does the second one only kick on if the car gets so hot???
Old Dec 28, 2003 | 04:05 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
The second fan kicks on later than the first one. I'm not sure of the temp but it's really high.
Old Dec 28, 2003 | 04:33 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
235-238 I think, maybe with A/C on as well
Old Dec 28, 2003 | 05:05 PM
fratsit's Avatar
Car: 1992 Camaro Z28 and '99 Camaro Z28
Engine: 350 TPI Supercharged
Transmission: Pro-Built Street/Strip 700R4
Axle/Gears: Stock
The second one will come on when the car reaches a certain temp. I cant recall the exact temp, but Dave Y is in the ballpark.
One fan is controlled by the ECM and the other buy a Fan Temp Switch. Also, when the AC is in use, and the line pressure rises, the computer will energize the second fan.
Sorry I don't have exact number's, but I can get them from the service manual if you want.
Frat
Honolulu
Old Dec 28, 2003 | 05:24 PM
BOTTLEDZ28's Avatar
Transmission: A4
There is a write up on this in the tech section. it says when each fan is suppose to turn on. Also, if you feel one fan may be burnt out, try switching the plugs on them and see if the other fan works
Old Dec 28, 2003 | 07:08 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
hey bottled your car looks really nice, do you have any interior shots with the new dash? i'd really like to see em..
Old Dec 28, 2003 | 10:06 PM
BOTTLEDZ28's Avatar
Transmission: A4
https://www.thirdgen.org/techbb2/sho...hreadid=169869
Old Dec 29, 2003 | 08:03 PM
TPI86TA's Avatar
Car: 88 GTA
OK thanks a lot guys.Do you guys think it would be a bad idea to wire the second fan so it comes on with the first fan???Thanks...Al in NJ
Old Dec 29, 2003 | 08:15 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
That's not a bad idea at all. It's pretty much agreed that even the first fan doesn't come on quite soon enough. Make them both come on at 180-190, and you should be set. It's a cheap trick that will help keep the engine cooler longer
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
Sanjay
Aug 12, 2015 03:41 PM
Leggman1
Aug 6, 2015 04:15 AM
