4th gen dash install pics
Old Mar 29, 2003 | 10:50 AM
BOTTLEDZ28's Avatar
Transmission: A4
heres some pics of my 4th gen dash install. not sure why the pics are blurry but you get the point
Old Mar 29, 2003 | 10:52 AM
BOTTLEDZ28's Avatar
Transmission: A4
Old Mar 29, 2003 | 11:18 AM
BTS88IROC's Avatar
Looks good! Are you done with everything or do you still have some minor things to finish? Also is that cowl hood functional at all? I see gauges in the cowl
Old Mar 29, 2003 | 11:31 AM
BOTTLEDZ28's Avatar
Transmission: A4
yes there is a few minor things I still wanna get finished. there is a bracket that is right in front of my hood release that Ihave to cut off and the glove box has to be adjusted a little. I am putting pics up in anotyher post on my gauges in my hood.
Old Mar 29, 2003 | 12:45 PM
HaroGt14's Avatar
:hail: Your car!
I love your car! It looks so sweet. Very clean nice job. I love the guages on the cowl. How hard was it to get that piece on the dash to fit up nicely against the window?
Old Mar 29, 2003 | 12:50 PM
BOTTLEDZ28's Avatar
Transmission: A4
Basically, I just measured from the window back to the dash in the middle. then took another measurement on the right and left side. I then put pieces of tape at those measurements on the 4th gen dashpad and used a spare 3rd gen pad to scrib a line along the 4th gen pad. I left a little extra material on the 4th gen pad in case my measurments where off but they werent and I had to go back and grind of more material to get it to fit nice. so, basicaly, it was a shoehorn job
Old Mar 29, 2003 | 01:11 PM
BTS88IROC's Avatar
Have you done anything with where the a-pillar trim is supposed to cover the holes in the dash?
Old Mar 29, 2003 | 02:44 PM
BOTTLEDZ28's Avatar
Transmission: A4
No not yet, the dashpad and my piller trim dont line up at all. there is a 2" gap on each side. Im gonna try and see what Ican do with a pair of 4th gen piller trims. If that dont work then Im just gonna put a piece of black plasitic in the gap to cover up the metal frame.
Old Mar 29, 2003 | 05:02 PM
84s/e's Avatar
Car: 1984 Firebird S/E
Engine: 5.0 lg4
That dash looks freakin good in there man. Nice job.
Old Mar 29, 2003 | 05:05 PM
BOTTLEDZ28's Avatar
Transmission: A4
Old Mar 29, 2003 | 05:26 PM
icebird_1981's Avatar
OMG u r so lucky!!!!!!!!!!i want a 4th gen dash in my car! but i just dont think i could do it, 2 much wires and i dont no anything about the wire i can make it fit in there i am sure but the wires oh just thinking about them... is there alot 2 deal with when it comes to the electriacl part of the swap??
Old Mar 29, 2003 | 05:28 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
very nice install there on the dash. I wouldn' t have wanted one from teh early 4th gens like you have, but its still nice anyway.
I am seriously considering a 4th gen dash for this TA of mine. Been looking for resources on how to do the swap.
So far, your install is one of the cleanest i've seen, besides Fatal88's
Old Mar 29, 2003 | 05:32 PM
BOTTLEDZ28's Avatar
Transmission: A4
Lets just say its not a plug in and go play situation. The 2 cluster harness connectors have to be cut off and spliced into the 4th gen conector wires. It took me about 4 days to figure ot which wires went to wich which wires but when I connected it and tested it, it was right on the first try.
Old Mar 29, 2003 | 05:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
I would rather have the newer style dash as well but they are harder to find and more exspenive. Plus at the time I didnt know what was up with the newer style GM gauges and digital odmeter.
Thanks for the compliments on the clean install but you gotta send some over to Custom X's. I like his the best. Its the color combo that makes it so good.
Old Apr 15, 2003 | 12:37 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Lookin' great man! I'm in search of the goods now to do the swap!
Old Apr 15, 2003 | 08:51 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
:hail: :hail: that looks really good your car looks awsome.
Old Apr 17, 2003 | 02:34 PM
Nightcruzer's Avatar
Car: Trans Am
Looks great. :hail: That's what hod rodding is all about. Not to mention that IMO silver/platinum/grey make the best looking colors on a 3rd gen.
Old Apr 17, 2003 | 06:42 PM
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Very nice job. Just replaced those same seats with Mr mikes seats. How did you get the speedo and tach all to work right? Once again nice job
Old Apr 17, 2003 | 06:47 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Mike,
Holy smokes those look great! :hail: I have been meaning to ask you about how you got your speedo working right with your trans? I would really rather not speed an arm and a leg getting the translator from jags that run. *shudders*
That dash assembly looks really clean in there, and that whole setup is probably cheaper than getting the translator for a t56, too. Hmmm......
Old Apr 17, 2003 | 08:28 PM
BOTTLEDZ28's Avatar
Transmission: A4
The tach was a basic plug and play deal. I just spliced the tach wire from the 4th gen cluster into the tach wire on the 3rd gen cluster, as for the speedo, I am running a T56 and tried to see if the speedo would work if I just hooked up the speedo wire to the VSS and it didnt. I already had the SGI-5 box so I used it and hooked it up the same way it was when I had the old dash. only problem is, the speedo is wacky and reads like 80mph at idle and works like a tach if I rev it at idle. As soon as I drive foward, it goes to zero and starts reading right. My 3rd gen speedo did the same thing so I think I have a wiring issue like a bad ground or something. Ill get to it now since the weather is getting nicer.
Old Apr 17, 2003 | 08:31 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
sweeeet....i want one
Old Apr 17, 2003 | 09:03 PM
Realmac4's Avatar
I have a T56 also so I use the SGI-5 box too. What about heat and ac controls. Also on your computer and engine mods who did the work and or burned a new prom?
Thanks Mike
Old Apr 17, 2003 | 10:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
I ditched the A/C and the heat only works out of the floor and defrost. I didnt bother running hoses for the vents. I never use them anyway. as for the engine and computer mods, I do all my work myself. I dont trust anyone else and I cant see giving my money to someone if I can do the same thing he can do to cars. As for the computer itself. I am still running a Ed Wright chip along with my stock chip. I havent got a chance to have a chip burnt for my setup. Im still running the stock heads until the warrenty expires. until then Im leaving it alone
Old Apr 20, 2003 | 09:38 AM
IHI's Avatar
IHI
Hey bottled, I'm in the same boat as you on the dash/vent holes by the pillars. Granted mines a bird dash, but the principles the same, I was talkin to a couple guys-first I stopped by an interior shop and they were kinda stummped about what to do and make it tie in correctly, then I talked the the guys that did all my body work, they told me to get the pillars out of the later models, and they'd cut them off and blend them into the original pillars and repaint so it'd look factory, so that to me is about the best option since the pillar is gonna fit our "original" car perfectly and the molded cover will fit the new dash like it's supposed too. Just got to get ahold of Bruce at Hawks again, then find some down time since the season starts in 2 weeks
Old Apr 20, 2003 | 04:44 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Fibreglass and bondo..........
Damn those seats look familiar.
Old Apr 20, 2003 | 08:54 PM
IHI's Avatar
IHI
[QUOTE]Originally posted by CustomX
[B]Fibreglass and bondo..........
I got enough bondo in the car when it got redone even though it's all lightweight bondo-I don't want anymore!!!
Old Apr 20, 2003 | 09:31 PM
WillWood's Avatar
Car: 1966 Volkswagen Beetle
Engine: Flat-4
Transmission: swing axle
Beautiful car, and I like the guages in the cowl hood.:hail: :hail: :hail:
Old Jun 10, 2003 | 06:55 AM
Ovrclck350's Avatar
[QUOTE]Originally posted by IHI
[B]
Mine'll be a bondo buggy by the time it's finished
Hey Bottled....did you happen to save/write down the wiring?
Old Jun 10, 2003 | 08:35 PM
BOTTLEDZ28's Avatar
Transmission: A4
ya i wrote the wiring down someplace. the thing with th ewirng is that all the years are diferent. your best bet is to just get both year books for the 4rd and 4th gen and start matching them up. get as many as you can and then ask me which ones have you stumped. are you in the middle of the swap now or thinking of doing it? My 4th gen dash and console is up for sale. Im asking $350 and its already trimmed up to fit in any thirdgen. its a 96 dash and console
Old Jun 10, 2003 | 09:34 PM
DaytonaFBody's Avatar
I had the same problem when I swapped the cluster in my 93 Z28 to a 95 cluster. The VSS signal for a 93 is like a third-gen, and the 94+ signal is different. If you have a 94+ VSS, it would probably make your new cluster work without the signal box. A 93 VSS would have probably made your 3rd-gen original cluster work with no converter.
My 93 had the same symptoms, 80 mph at idle, revs like a tach. I just put the 95 face on my 93 cluster to solve it. It's in the electronics, I think your converter box is unnecessary.
Old Jun 11, 2003 | 07:23 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you get this done, can you let me know how it looks? I'd be very interrested in seeing how they are going to join two textured plastic panels so that the texture looks continuous.
Old Jun 11, 2003 | 10:32 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Killer job on the install!
Congrats!
Old Jun 11, 2003 | 03:29 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Looks nice!!! I like the stock look but I would have to say it looks real good!! Plus Realmac4 i love that Z28 seat!!!
Kevin
Old Jun 11, 2003 | 08:24 PM
BOTTLEDZ28's Avatar
Transmission: A4
well the dash is up for sale so the VSS issues I have will be adressed when I get my new autometer speedo and cluster setup put together. Hopefully I can figure out this VSS signal crap. the worse part about it is that if I hook the VSS signal up with the SGI 5 box, my idle goes up to about 1100RPMS. I cant figure it out.
Old Jun 11, 2003 | 10:01 PM
Ovrclck350's Avatar
I have a 91 Z28 too is why I was asking Our wiring should be the same.
My dash (I scored complete interior for $125) is from a 95 Formy, so wiring should be the same as yours.
Right now I'm in the planning stage. I think I'm going to replace the carpet while I'm at it since I'm ripping the complete interior out. I'm also gathering a lil bit of cash for the misc. expenses I'll prolly come across. I know I need to figure out a way to connect the dash vents, so I just need to sit and look right now.
Old Jun 12, 2003 | 10:32 AM
LowCamaro's Avatar
Car: 1985 Camaro
Engine: ......
Transmission: ......
I am extremely interested in completing this swap as well, As for the gauges, im going to use all autometers, and mount then in a template where the factory 4th gen cluster is...other gauges that wont fitt will be mounted in an A-Piller pod. Other things im worried about are the heat issue, gaps i can fill myself, and the console im also worried about. I have an auto with a B&M console megashifter...and im not too sure how ill be able to make it match up with the 4th gen console...maybe some cutting
Old Jun 12, 2003 | 03:11 PM
Fatal88's Avatar
Car: 1988 Z
you are correct..
is this the area you are referring to???
Old Jun 12, 2003 | 04:13 PM
Ovrclck350's Avatar
Fatal, you make those?
if so, how much you want for another set? (Once I get done w/ my project tho).
Old Jun 12, 2003 | 08:23 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
Originally posted by DaytonaFBody
IThe VSS signal for a 93 is like a third-gen, and the 94+ signal is different. If you have a 94+ VSS, it would probably make your new cluster work without the signal box. A 93 VSS would have probably made your 3rd-gen original cluster work with no converter.
You might be right. Of course, swapping the vss with also require swapping the corresponding gear on the output shaft of the transmission. Not sure how difficult that is on a 6-speed tranny.
Old Apr 3, 2004 | 04:49 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
ill be doing a dash swap as well this summer. a 02 dash in a 88 model. if fatal would kindly make a set, id buy them for sure.
dash looks great. post has arisen from the dead. :hail:
Old Apr 3, 2004 | 05:18 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Nice, I cant wait to get to mine.
I scores a COMPLETE 94 TA Int. for $238
Dash,console,pillars,and front and rear leather seats
Old Apr 3, 2004 | 05:31 PM
BOTTLEDZ28's Avatar
Transmission: A4
holy crap, you keeping the seats?
tpi383, I sent you a PM about your engine did you get it ?
Old Apr 3, 2004 | 05:40 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Yup fatal
Although im still messing aroudn with my close cell foam dash pad and trying to make a set of covers that fit perfect......just takes time and im willing to take the time as Id like it to look as nice as possible.
Old Apr 3, 2004 | 11:51 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
4seats are MINT. D.side has the damm usualy little rip on the side bolster as you get in. Im gona see about getting that fixed befor I sell em. ( Local shop said around $75 to fix but bring it up for em to see it.
I couldnt pass up the deal so cheap. I can easily make that back on just the seats once I get the D.side fixed. They arnt power but they do have the Air Lumbar in both of em.
All I really wanted was the Dash/console
cant use the back seats with a 8point cage anyways
No PM that I rem. E-mail me
Chris@cecoatings.com
Old Apr 4, 2004 | 12:09 AM
chevyrumble83's Avatar
Car: 1983 Z28
that looks amazing u did a perfect job, i really do envy u lol. i wish i had the skills,and time to do that. the interior is the one and only thing i hate about my camaro>one it looks so old two it looks so cheap and boxy hey how about i pay u to install one in my Z LOL.
Old Sep 3, 2012 | 05:22 PM
camaroking16's Avatar
Re: 4th gen dash install pics
bottledz28 you still wouldnt have that dash laying around would ya
Old Sep 3, 2012 | 07:23 PM
BOTTLEDZ28's Avatar
Transmission: A4
And the thread comes back from the dead!!! I took that dash out years ago and put the stock setup back in minus the cluster. The money I got from the 4th gen dash I used to buy Auto Meter gauges.
Old Sep 5, 2012 | 10:32 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Its not as bad as it seems heres a wiring diagram for 96 dash into an 86 iroc also a link to the dash swap im doing
https://www.thirdgen.org/forums/inte...dash-swap.html
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
