Is running rich bad?
Old Dec 29, 2003 | 08:58 PM
StealthElephant's Avatar
Car: 87' Iroc
Does running slightly rich hurt anything over time (other then fuel economy)?
Obviously being lean creates a heat problem, but does running rich cause any mechanical damage? Alot of FI guyes run rich as a safety....
Old Dec 29, 2003 | 09:24 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
its really bad for a catalytic convertor.
its really bad on fuel ecconomy.
and it fouls plugs.
if your car is running rich, find out why it is running rich and fix it.
Old Dec 29, 2003 | 09:28 PM
Car: 87' Iroc
My car isn't running rich, I'm just curious.
So it doesn't cause any actual damage to the engine? Running lean can cause overheating, preignition...etc etc, that can destroy an engine....can running rich damage an engine?
Old Dec 29, 2003 | 09:34 PM
RJR99SS's Avatar
It's not very good for power or fuel economy. But it wont cause any "physical" damage besides creating a lot of soot; fouling plugs and clogging cats.
I saw a few times where rich running cars had a pinging problem because of the vast amount of carbon in the combustion chambers retaining heat.
Old Dec 29, 2003 | 09:50 PM
Car: 87' Iroc
So theres no truth that running a little rich will help cool the cylinder down slightly?
Old Dec 29, 2003 | 09:52 PM
RJR99SS's Avatar
The key word is "slightly".
I'm not sure why you would need that, unless we're talking heavy duty racing.
Old Dec 29, 2003 | 10:01 PM
Car: 87' Iroc
It seemed like most people have the attitude that it's better to be rich then lean, but I someone posted that it's not good to be rich either. Personally replacing a Cat is easier then replacing an engine.
Old Dec 29, 2003 | 10:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think quantifying the answer is in order.
Running rich for a prolonged period of time, will most likely hasten cylinder bore/ring wear.
The old saying "rather rich than lean" should only be used during the tuning cycle../WOT blasts when rich will probably cause much less damage that WOT throttle blasts when lean.
The idea should be to tune the engine so it's right, not leave it rich.
Old Dec 30, 2003 | 01:45 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Running rich (like 11.5 or 12.5 : 1) is a must at WOT for combustion chamber cooling which helps prevent detonation.
How rich it's running is important. If it's waaay rich, the fuel will wash the oil off the cyl walls which accelerates wear. Fuel can also contaminate the oil leading to excessive wear all through the eng.
If it moderately rich for a short period, the eng will probably be ok.
The cat won't be too happy abt it.
If it's allowed to continue for a long period, the soot will build up in the combustion chamber. This causes the compression to increase and leads to detonation and possibly pre-ignition..
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
