screw in studs installation ?'s
Old Jan 4, 2004 | 05:04 PM
onebinky's Avatar
Is installing screw in studs as simple as removing the press fit studs, and tapping the holes for the screw-in studs?
Is it that easy, or should I pay the money to have a machine shop do it.
Thanks guys,
Matt
Old Jan 4, 2004 | 07:14 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Hopefully this still works.
If so, thank Vader. He posted that a while ago.
You need Adobe Acrobat to read it.
http://216.121.161.76/files/RockerStudReplacement.pdf
Old Jan 4, 2004 | 08:11 PM
onebinky's Avatar
Thanks Vader
That's a very informative article, thanks for posting it up AJ. At least I know I can do it, and I can put that $80 labor towards something else.
They should stick that article in the tech section on the main page, very good info...
Old Jan 4, 2004 | 09:03 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I guess if you trust your machining abilities you could do it but I'd rather pay a shop $60 to do it for me
Old Jan 5, 2004 | 04:27 AM
ede's Avatar
ede
it's not quite that easy if you're using a preformance stud instead of a repair type stud. you need to machine .4 off the stud boss. there are several DIY cutters for that. lot of people report great results using them. i have a couple or had a couple that were worthless. i'll still with a vertical mill.
Old Jan 5, 2004 | 11:42 AM
onebinky's Avatar
Ede, does that hold true with vader's method too? He said something about using a different type of stud with a round base and didn't mention anything about making the holes deeper.
Thanks for all your help
Old Jan 5, 2004 | 11:44 AM
ede's Avatar
ede
what he posted works for a repair stud for when a pull out studs pulls out. a regular or preformance type stud, with a hex on it, will need to have .4 milled off the boss. the holes don't have to be made deeper.
Old Jan 5, 2004 | 09:27 PM
onebinky's Avatar
oops, I guess I misunderstood what you said about the milling
I'll have to do some more research then on if that repair type stud will be strong enough for me.
Thanks again guys
italiano67
Dec 11, 2016 09:21 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
camaro71633
Sep 1, 2015 10:24 AM
LT1Formula
Aug 20, 2015 09:36 PM
TheJoeY88
Aug 13, 2015 06:51 PM
