Dead after first start attempt on new engine
Old Jan 13, 2001 | 05:23 PM
cfabe's Avatar
Just finished in the swap listed in my signature. Went to crank the engine for the first time, heard a click, then nothing. After the one click, all electrical in the car is dead. I figure i somehow blew a fusible link or something, anyone have any ideas where to start looking? Or something else that could cause this?
82 T/A 305/TH350; soon to be 350/T-5
Old Jan 13, 2001 | 05:35 PM
Blade's Avatar
Try the fusible link that is in line with the wire that goes from the battery to the starter directly.
Old Jan 13, 2001 | 05:38 PM
Vader's Avatar
CFabe,
Battery connections, starter connections, engine ground connection, all the standard stuff first.
The fresh paint on the new engine might be causing a grounding problem.
Beyond that, the positive and ground nodes on the body near the battery, then fusible links.
Tried jumping the car?
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Old Jan 13, 2001 | 10:18 PM
robert mendoza's Avatar
I had the same problem when I completed my engine swap. My problm was the ground to the block was not making good connection as stated in vaders reply.
Old Jan 13, 2001 | 11:41 PM
cfabe's Avatar
The engine is far from painted (gonna run it as i pulled it and then rebuild later this summer), but I will check the engine/chassis ground strap, hadnt thought of that. Didnt try jumping it, but I'm sure the battery was good, i had just charged it. Also, voltmeter in the car was reading about 13 before the start attempt. Going to check conenctions and fusible links now, I'll post agian when i find something.
Thanks for the ideas guys.
Old Jan 14, 2001 | 10:22 PM
cfabe's Avatar
Problem turned out to be that we forgot to tighten the connections on the starter. Overlooked the obvious. Thanks for the help!
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
