deciphering main cap P/N's
Old Jan 5, 2004 | 12:35 AM
onebinky's Avatar
I'm starting to go through the parts for my disassembled 350 engine that I've had sitting around for a couple years. When I took it apart, I didn't know that they wear in a specific pattern and I didn't label them.
They all look identical to me, but they have 3 different part numbers which I'm hoping will tell them apart. They are 752, 764, and 806. Anyone know which goes where?
Other than that, the mains are straight and alligned, but if I can't get a correct order on these I'll probably need to have the ends on the caps and the webbing milled, and then have the mains allign bored. Which of course is more money that I could put somewhere else in the motor...
Old Jan 5, 2004 | 04:12 AM
ede's Avatar
ede
take it to a shop and have it alighn honed.
Old Jan 5, 2004 | 11:39 AM
onebinky's Avatar
no way around it then...
Alright, better safe than sorry
Thanks Ede
Old Jan 5, 2004 | 11:47 AM
ede's Avatar
ede
as far as i know there isn't. however if i were wanting to not go to the trouble or expense of alighn boring i'd bolt the caps up and checl the diameter and out of round with a bore gauge and check how close thay all are to each other with a straight edge, .001-.0015 is acceptable. i wouldn't risk it since most likely you'll have the block in the shop anyway.
Old Jan 5, 2004 | 09:24 PM
onebinky's Avatar
According to their website, they are wanting to charge me $250 for the align bore. Is that pretty a fair price for that job? I'll spec em like you said and see if they are far enough apart where I can tell what goes where. If that doesn't get me anywhere, I'll have them machine it.
Stryker412
Sep 20, 2015 06:59 PM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
TBRays98
Sep 6, 2015 05:05 PM
greenyone
Sep 2, 2015 03:39 PM
