Having crank turned? What is safe?
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have a crank my friend gave me that needs turned.
It is a scat 9000 crank and I am only building up say 400-425 hp 383. Nothing too radical.
I have not been to my machine shop yet to have it checked. What is the safe range to have it turned. I know that 10 under would be fine, but what about 20 under? It has one bad scratch that 10 under might not take out.
Would you guys use a crank that was turned 20 under?
Remember, its a freebie so I really cant lose if I dont use it.
thanks.
thanks.
it's good for anything you can buy bearings for. there's a reason someone gave you a scat crank. considering how cheap cranks are i'd keep looking, especially when you add it the cost to have it ground undersized. call autozone. you can buy a gm crank from them with bearings for less than 200 dollars. consider bearings are going ot cost you around 75 it isn't bad price.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I had also looked at the eagle and pbm cranks. I dont need forged. What would you suggest then.
i'd worry more about the finish and straightness of a crank for a 450 hp application then i would if it's strong enough. in other words have the crank inspected and blueprinted and don't get all wrapped up in running a high dollar piece and thinking that's the end of it, just laying your money down and having a good part to run. if you believe DD2000 i built a 350 few years ago for my sons car that was over 450hp and ran a stock cast crank. for the record i don't really believe it was over 450 hp like DD2000 said. my guess would be more in the 415-425 range.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
As far a getting everything straight and balanced for the 383, I have a great machine shop.
I just dont want to put a crank in a motor and have it fly apart after everything is said and done. Id rather be safe than sorry.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Do you think the stock L98 crank would be safe up to 425 hp in a 355? Say spinning it to 5800-6000 rpm?
Of course I would have the cranked checked and polished.
Car: 4
Engine: 6
Transmission: 5
You're going to have a tough time getting a 350 to put out 425 HP at 6000 RPM or less.
But yes, at RPMs below 6000 with no nitrous, a stock crank is fine, with the appropriate minimum maintenance machine work done to it as you describe.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Off the subject but couldn't you just get a 350 put fast burn heads and an LT4 HOt cam and get 430 HP?(aka ZZ430)not too tough. I don't think that people take the HOT cam to more than 6000 rpm I don't. My engine dynoed at 408 hp with vortecs and HOt cam at 5600 rpm, that's close.
