Oil pan,how difficult?
Old Jan 16, 2001 | 04:35 PM
BenIroc's Avatar
I´ve put in a new cam, and I´m going to change to one piece pan seal now when I have the pan a little ``loose``
Old Jan 16, 2001 | 04:47 PM
ede's Avatar
ede
the pan doesn't matter. there is a seal adapter (or what ever it's called) bolted to the back of the block that the seal sits in ,what you need to do is drop the trans to change the one piece oil seal.
ICON Motorsports
1st & 3rd
Old Jan 16, 2001 | 04:55 PM
Birmass's Avatar
You are refering to the one piece rubber gasket for the oil pan I believe. You will have to remove the starter and oil filter. The rest is just getting the oil pan bolts out. It's pretty simple to do. The pan will drop down, but getting the gasket on there will be tough because you'll have to go under the crank which will still be inside the pan because the pan won't be low enough. You should jack the engine up some to get the pan low enough to slide the seal under the crank.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
Old Jan 16, 2001 | 05:48 PM
ede's Avatar
ede
oh sorry i misunderstood what you were asking, not the first time i got stupid on here.
ICON Motorsports
1st & 3rd
Old Jan 17, 2001 | 07:10 AM
BenIroc's Avatar
Ede, no problem man, I understand you went
for the difficult one.
Birmass thanks for your answer, yes I was
fearing that the oil pan wouldn´t want to come out easy, well well I have bought the
one piece gasket and I have to do it, its
a dirty jobb but........ .Now if I´d dare
to buy a better pan now and put on it that
would be something but the budget its tight.
BenIroc
89 Iroc, TFS ported heads, f*rd 9´´ rear end
new cam, headers, etc etc
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
