REAL big block GTA info Please !!!
Old Jan 12, 2004 | 10:24 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
I Found a 396 big block off a Chevelle ss 70 in a trans am GTA 88 5 speed transmission from a 69 corvette with 486whp "dyno verified". The car is mint condition for 5000$can. What should i look for not to get screwd ? and is it possible to lower the suspension with that heavy block ? The car is very high in the front now since it as a pretty beef up suspension and not the original Ws6 package... Please let me know what u guys think about the car and how fast should it go down the 1/4 mile ?
Old Jan 12, 2004 | 10:37 PM
84H.O.Trans Am's Avatar
Car: 84 Trans Am
Axle/Gears: 9in 4.30's
Re: REAL big block GTA info Please !!!
sorry to inform you but there was never a 5 speed manual trans in 1969...infact there was never a 5 spd manual trans in any corvette..the only options were close or wide ratio 4 speeds until the horrible 4+3 speed was added in 1984...the next change occured in 1989 with the ZF 6 speed. my best guess its a t-5 stock or rebuilt...as for the 396 engine...check the engine casting numbers online...because just from the transmisson story it sounds like someone's full of crap.
good luck.
Old Jan 12, 2004 | 11:31 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
And with that much power through a T5, you'll coast through in maybe 40 or 50 seconds, because it'll puke it's guts out before you hit second gear.
Old Jan 13, 2004 | 06:08 AM
ede's Avatar
ede
i'd run the numbers to make sure what you really have. look over the quality of the work, is it neat or not? the bbc isn't that much heavier than a sbc, 200-300 pounds. i'm not sure i'd trust the dyno sheet, all you have is a dyno sheet and no idea what engine it's really for.
Reborn756
Sep 4, 2015 03:42 AM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Leggman1
Aug 6, 2015 04:15 AM
