TDC question with cam placement
Old Jan 15, 2004 | 10:06 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys when the 2 dots are lined up on the crank and cam that means you are fireing on the number one cylinder right? I just want to make sure i am so when i go to initially set the valve lash its all fine. thanks
Old Jan 15, 2004 | 10:13 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
No.
When the cam dot is at 6 o'clock, and the crank dot is at 12 o'clock, the #6 piston is at TDC firing position
When both are at 12 o'clock, then the #1 is at TDC firing position.
The nice thing is, when setting the lash, you can use this sequence, and when you're done, the #1 piston will already be at TDC waiting for you to drop in the dist.
With #6 @ TDC, set lash on ......
#3 Intake valve
#5 Exhaust valve
#7 Exhaust valve
#2 Exhaust valve
#4 Intake valve
#6 Exhaust valve
#6 Intake valve
#8 Intake valve
With #1 @ TDC, set lash on ....
#1 Exhaust valve
#1 Intake valve
#3 Exhaust valve
#5 Intake valve
#7 Intake valve
#2 Intake valve
#4 Exhaust valve
#8 Exhaust valve
Old Jan 15, 2004 | 10:27 PM
Car: 89 Formula
Engine: Carbed 5.7
alrigth so right now i am fireing on number 6 so i should leae it and adjust the valves i can and then go 360 on the crank and do the others and i will be fireing at 1 so the dist will go in, damn man good call. thanks alot
Old Jan 15, 2004 | 10:55 PM
AJ_92RS's Avatar
If anyone, thank RB. He's the one I learned about the #6 firing thing from.
Old Jan 16, 2004 | 06:20 AM
ede's Avatar
ede
all the manuals i've ever seen tell you to install the gears dot to dot which makes it easy to line up but it's not in time dot to dot. you need both dots straight up. the manuals out to put a disclaimer in there telling you dot to dot is 180* out of time.
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
