fel-pro one piece oil pan gasket
Car: 1982 Z28 Indy Pace Car
Engine: 305 LU5
I just completed replacing the rear main seal on my 82 305. Of course, I had to also replace the oil pan gasket. I used the new one-piece fel-pro oil pan gasket. It's a huge improvement over the old 4 piece gasket set. However, I do have one problem. The new style gasket is much thicker. So, it spaced the oil pan further off the block enough to cause and interference with the exhaust Y-pipe. The pipe is in contact with the oil pan in two places (lower edges of pan). So, I'm planning on pulling the exhaust and getting out the hammer. I estimate the pan is 1/8 inch lower.
Beware,
Ken
82 Indy Pace Car
Beware,
Ken
82 Indy Pace Car
Had the same problem!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Hey I had the same prob too. To answer the last question, Yes you can reuse the gasket since it is rubber. Just inspect it before you put it back in. Make sure there is no cuts, gouges or is not deformed to bad. Deforming shouldn't be a big prob because the fel-pro puts crush limiter into that particular gasket. Although you will have a little forming into the shape of the block and pan which is ok al long as its not too bad
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
