Is a L98 a 4 bolt?
Car: 91 Z28
Transmission: built 700R4
Is a L98 a 4 bolt?
quick question, is the L98 a 2 or 4 bolt main? I have searched but came up with nothing. thanks
Originally posted by ede
suspose to be 4 bolt l98 in vetts. 2 or 4 bolt doesn't amker a lot of differance and a 2 bolt can be converted
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
i have seen a few 4-bolt vette blocks as well as 2-z's and 6 t/as in my mechanic history,17yrs. not to say there are not more out there those are the ones i have come across from 1989-pres.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Originally posted by 87350IROC
does anyone actually have any pics of a 4bolt L98? I have yet to see one and i wonder why random ones would have four but most 2.
One last time. Most Corvette L98 cars did have 4 bolts. But NO!! And I mean NO!!!! Fbody car with a L98 came factory with a 4bolt. Ever! The only way an Fbody car got a 4 bolt, is if the engine has been changed to a 4 bolt.
Engine: T.P.I L98.
Transmission: TH350
but there are so many people including me who have seen original engines from corvettes that are two bolts
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Ya know what. It really doesn't matter what car, truck or van the engine came out of. The only way to find out if the engine is a 4 bolt main is to.....
PULL OFF THE OIL PAN AND LOOK!!!
All the "could be" and "should be" and "will be" comments don't tell you a damn thing.
Engine: T.P.I L98.
Transmission: TH350
Originally posted by SMasterson
This is incorrect information.
Engine: T.P.I L98.
Transmission: TH350
I did a bit more research, and I may stand corrected on the fact of the Vettes mostly having a 4 bolt. Because after 1984 the only real GM vehicle that infact came with a 4bolt from GM were 3/4 ton or bigger Trucks and vans. This is right from GM themselves.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
