Maybe my most stupid question yet!!!
Old Jan 21, 2001 | 11:12 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Alright, I did something a little dumb, I got the "wrong" spark plug wires. But are they? They are Accell 8.8mm wires, for the 1987 trans am w/ v-8 (universal fit) However, the have stright boot on one side, and 90 degree on the other. My current wires have 90 degree boots for the spark plugs and distributer. Well, I checked the stright boots clear the bood when put on the distributer cap, but do I have to worry about them falling off? (See I told ya, a real dumb one) If I have to return 'em I gotta dig for the reciept....(yuck)
Corry
Old Jan 21, 2001 | 11:46 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The straight boot is for the spark plug(s). With GM V8s, they use "mixed" boots on the spark plugs (and 90* on the distributor). If you switch to headers, then most people will use 90* boots on the spark plugs to clear the primariy tubes of the headers (but still 90* boots on the distributor).
IF you have a straight boot on the distributor side AND it is NOT a spark plug boot; then someone at the manufacturer f'd up.
Old Jan 22, 2001 | 12:13 AM
Corry's Avatar
Car: 1987 Trans Am
Well, I got the SLP 1 and 3/4" headers, so looks like I'm digging through some trash/reciept piles. Never thought to look at the length of the straight boots
Thanks for answering the dumb question
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
SLP 1 3/4" headers, 3" cat back (stock cat )MSD ignition. MSD Blaster SS coil. More soon when funds are avail...
Old Jan 22, 2001 | 04:39 AM
theformula's Avatar
Hey dont feel bad I made the same dumb mistake before.
Anyway, with headers you're going to need custom fit wires anyway. It's where you cut each wire to your desired length. Also, pick up some wire separators. They are only like $6. You don't need the $40+ wire looms either.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Cold air ind. w/K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, SLP headers & catback,short shifter,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
masonta
Sep 1, 2015 06:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
