L98 heads, which ones ?
Old Jan 22, 2004 | 04:32 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
It is my understanding that L98 heads had different bolt patterns through certain years. What years would be compatible with my 87 IROC 350 L98 ?
Old Jan 22, 2004 | 05:04 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
'87 & up
Old Jan 22, 2004 | 09:17 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
What are you talking about by "bolt pattern"?
If you are referring to the center bolts for the valve covers, then (as above) I think that '87 and above had center bolt valve covers. I have an '87 L98, they are center bolt valve covers.
Old Jan 23, 2004 | 08:45 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Originally posted by scottland
'87 & up
What he said + not LT1 or LS1.
Old Jan 23, 2004 | 08:50 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
No, the bolt pattern he is probably talking about is on the heads where it meets the intake. The 2 center bolts were at different angles than the outer bolts. I wanna say it was between 87-89 that it changed but I'm not sure. Someone will know the exact date for sure.
Old Jan 23, 2004 | 10:21 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
1987 model year.
Old Jan 23, 2004 | 10:46 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Originally posted by five7kid
1987 model year.
Unless you are talking a Corvette L98 (aluminum heads), they all had the old style bolt angle.
Old Jan 23, 2004 | 11:05 AM
five7kid's Avatar
Of course...
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
TheExaminer
Aug 19, 2015 10:07 PM
anesthes
Aug 8, 2015 09:37 PM
