Head Gasket Replacement?
Old Jan 24, 2004 | 03:14 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
I think I have a head gasket that needs to be replaced. There is what looks like foam in my radiator and bubbles in the overflow tank. The antifreeze will be a little low but there is no oil in the antifreeze and no antifreeze in the oil.
What I am wanting to know is what is all needed for parts when replacing the head gaskets and what are the better types of head gaskets and head bolts to get for my car and also what size the gasket needs to be like the bore size and thickness they need to be on a stock 350 TPI engine.
I do know that I need the new head gaskets, head bolts, gasket sealer, new antifreeze, new oil and new oil filter. Is there anything else that I might need to get to replace the head gaskets. Please let me know if I have missed anything.
Old Jan 24, 2004 | 03:33 PM
camarocruzin's Avatar
Car: '89 Iroc
Transmission: 700-r4
a few that come to my mind are those plus intake gaskets, header gaskets probably, i would assume valve cover gaskets also, someone corect me if I am wrong, and i am sure there is more, but those would all be on my shopping list.
Old Jan 24, 2004 | 03:36 PM
ede's Avatar
ede
just buy a head set and you'll get all the gaskets you need. i'd try a little trouble shooting and testing before jumping in and r&ring the head gasket when that may not be your problem.
Old Jan 24, 2004 | 03:50 PM
Gambit69's Avatar
What other problem do you think would be causing the bubbles in the radiator?
Old Jan 24, 2004 | 03:55 PM
Car: '89 Iroc
a few that come to my mind are those plus intake gaskets, header gaskets probably, i would assume valve cover gaskets also, someone corect me if I am wrong, and i am sure there is more, but those would all be on my shopping list.(if it is a head gasket that is)
Old Jan 24, 2004 | 04:46 PM
Morley's Avatar
To check the head gasket get an air fitting that screws into the spark plug holes, Start with the one you suspect might be bad (usually #8) put the fitting in the plug hole and hook air to it with both valves closed (may have to rotate the engine by hand to get on compression stroke for that cylinder) apply 50-80 psi to the cylinder and look for bubbles in the overfolw tank. Keep checking all of the cylinders until you have found the leaker or until all are done without finding a leak.
Get Felpro head gaskets, a set of good valve cover gaskets, Permatex ultra black RTV and an intake gasket set for TPI (it will have all the gaskets for the plenum, base, T/B, etc.). AND, while you have the heads off, you may as well replace the valve stem oil seals. That should do it for gaskets, remember you'll need a torque wrench.
Old Jan 24, 2004 | 06:10 PM
ede's Avatar
ede
combustion gas tester is a little less work than using air to look for bubbles
Old Jan 24, 2004 | 08:05 PM
Gambit69's Avatar
Where do you get a combustion gas tester and about how much do they run?
Old Jan 25, 2004 | 07:13 AM
ede's Avatar
ede
most if not all the speciality tool makers have them. mine is snap on and cost around 50 dollars. i'd guess you could find someone to test it for you for around 10 or 15. it takes next to no time or effort to do.
Old Jan 26, 2004 | 07:52 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Felpro head gasket set + Felpro intake gasket set = good, but BLACK RTV?, Why don't ultra GRAY RTV?. Is't the best or not?.
Denis V.
Old Jan 26, 2004 | 08:47 AM
ede's Avatar
ede
only rtv i use is ultracopper. i hear ultragrey is very good, but i lke ultracopper. i've used it for head gaskets before, not with head gaskets instead of head gasket.
Old Jan 26, 2004 | 09:49 AM
kevinc's Avatar
Car: 1982 Z28
Check to see if the gasket set you buy comes w/ the TPI stuff...runner gaskets specifically. If not, FelPro and ROL sell a TPI plenum/runner/TB gasket set for like $11 or so.
As ede mentioned, troubleshooting while it's still together is the right next step before disassembly. If you open your rad cap and the contents smell like exhaust, it's a dead giveaway. Antifreeze has a distinctive smell so if there's exhaust contamination your nose will tell you. NAPA sells a kit for ~$50 if you don't trust your nose.
I don't see much value in diagnosing it down to the specific cylinder...it's not a decision point unless you're only pulling one head.
While the heads are off, you want to have a machine shop pressure test them. This will rule out them being cracked. If they pass pressure testing, have the shop check the surfaces for trueness and mill them if needed...same amount on both heads so you end up with no compression variation.
Old Jan 26, 2004 | 10:19 AM
Morley's Avatar
Denis V.
Permatex Ultra black used to be named "OEM Black" because that is what GM used when our cars were made. I've never had the Ultra black fail.
Old Jan 26, 2004 | 10:48 AM
Denis.V's Avatar
Axle/Gears: No idea
O.K., black RTV was OEM, but note that black was used with engines NEWs, with perfect surfaces in block, heads and intakes Today these engines had 15 - 20 years old (5,475 - 7,300 days = 5,475 - 7,300 starts ON/OFF = 5,475 - 7,300 heat/cold, heat/cold, heat/cold, etc.....), and too many accelerations from 0 to "n" miles/kms/hour. And factory assembly v/s an own re-assembly is not the same. For this reason, I say (my opinnion) ultra gray or similar, Permatex or Loctite.
Denis V.
Old Jan 26, 2004 | 11:18 AM
ede's Avatar
ede
not that gm would ever make a mistake, but i think doing something, or using black rtv, just because gm did or does may not be a good idea.
Old Jan 26, 2004 | 11:55 AM
Morley's Avatar
See the last statement in my post above. And no, my engine never leaked with the RTV that GM applied either.
Old Jan 26, 2004 | 05:54 PM
kevinc's Avatar
Car: 1982 Z28
I prefer the copper stuff.
GM also put 15" rims on my Z from the factory, doesn't make 15" rims the best thing to use.
Old Jan 27, 2004 | 07:15 AM
Denis.V's Avatar
Axle/Gears: No idea
I've my Loctite RTV (sorry for my english: it's GREY, no gray). It says: "meets and exceeds OEM specifications". Since it's a good USA's product, I think this is true (a lot of chinese products says the same, but....).
Denis V.
Old Jan 27, 2004 | 08:16 AM
ede's Avatar
ede
denis way back in the late 70s when i was spinning wrenches for a living there were lot of counterfit parts. one i remember said motorCAR and was packaged to look like motorCRAFT. along same line one place i worked arounf 1990 got thousands of cheap bolts with grade 8 markings, we trashed everything and started over instead of trying to test and sort out the good from bad. kind of goes along with you saying lot of chinese parts are marked "made in usa"
Old Jan 27, 2004 | 11:16 AM
Tribe's Avatar
Car: 1992 Z28
I have a 92 with 305 TPI. I am going to replace my head gasket soon as well. Does anyone know which ARP bolts to get?
Old Jan 27, 2004 | 02:10 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
I never have a problem using red rtv... its all I use
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
MY87LT
Aug 17, 2015 08:43 AM
