How the heck do you get the crank pulley off???
Old Jan 24, 2001 | 02:36 AM
Dan87IROC-Z's Avatar
Its like, the last thing I have to remove so I can swap in my new cam, and I can't get it off. Whenever I put a wrench on ANY of the bolts, it rotates the engine, how do I stop this or what do I do to get the crank pulley off?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.6:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Old Jan 24, 2001 | 04:17 AM
BenIroc's Avatar
Dan,get under your car and take off the
cover of the converter- flywheel ( 4 bolts ).
Take a screwdriver and lock the starter ring gear on the flywheel, then you can remove the
pulley.
Or if you have a strong buddy to help you,
he can hold the pulley with the help of a towel or something to get a good grip on the
pulley, and then you remove the bolts, but
he better be strong because it´s hard to do it that way
Good luck.
BenIroc
89 Iroc , TFS heads, ford 9´´ rear end, etc etc.......
Old Jan 24, 2001 | 07:37 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
Engine: 1998 L31 350
Transmission: 700 R4
Here is a suggestion, use an impact wrench. It won't turn the engine. I once put pulleys on a rustang and that was the only way I could get it off. Hope this helps.
Old Jan 24, 2001 | 02:53 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I always use the old 'long screw driver in the flex plate' trick too.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Jan 24, 2001 | 08:33 PM
BTT
Old Jan 24, 2001 | 08:38 PM
LottaBallsCamaro's Avatar
You can also hit the end of the rachet with a hammer. This acts like an impact gun only you can brake stuff alot easier...
Pretty damn smart with cars for 17!
91 Camaro RS, 305 TBI
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
Edelbrock MPFI system.
RAM air hood & Z28 wing.
Z28 cam.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
Old Jan 24, 2001 | 09:17 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
if none of those techniques work, they do make pulley pullers, which i think sell for around $20,
by the way could you email me and tell me how putting the new cam in works out for you, i just installed a summitt cam, lifters, and timing chain. well we got the engine all back together, it started right up and broke in the cam. the next day it took about 2 hrs. to get it started and it stalled out. well that was 3 weeks ago and still nothing, but oh well i am dropping a 350 in it. that better start.
email buffshields@yahoo.com
Old Jan 25, 2001 | 02:28 AM
Pat Hall's Avatar
Go with NC's suggestion. A good 1/2" impact wrench will succeed probably about 99 percent of the time. Also remember that the center balancer retaining bolt also holds the pulley on some engines.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
RS Reaper
Oct 17, 2018 07:52 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
