What kind of valve cover gaskets do you recomend?Rubber,cork,etc.....?
Old Jan 26, 2004 | 07:48 PM
TPI86TA's Avatar
Car: 88 GTA
What kind of valve cover gaskets do you recomend?Rubber,cork,etc.....?I need to get some for Trans Am..Thanks...Al in NJ
Old Jan 27, 2004 | 12:36 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: What kind of valve cover gaskets do you recomend?Rubber,cork,etc.....?
Rubber...I am using the gaskets that Nascar uses on their cars though. Very pricey...
Old Jan 27, 2004 | 01:14 AM
ronterry's Avatar
Car: '94 Corvette
'CaptPicardsZ28' I'm wondering if your talking about the Moroso rubber gasket with the steel core? Anywho, that's what I'm running, and yea they run about 30 bucks.
Mr Gasket makes a composite gasket which works pretty good also.
What ever you do don't buy a cork gasket, and use a tube of RTV to get it to seal.
Ron
Old Jan 27, 2004 | 04:56 AM
ede's Avatar
ede
i didn't know you could still get cork. that's like dark ages. i use fel pro gaskets.
Old Jan 27, 2004 | 07:47 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
rubber over a steel core.
theres a circle track store that sells the EXACT SAME ones as the Moroso $30 ones for $9.95.... i got the link off this site.... if you do a short search you could find it...
i also see them go cheap on ebay...
Old Jan 27, 2004 | 09:58 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Maybe im just lucky but ive never had any problems with cork. Even got a cover to seal with only 3 of the 4 bolts and a cork gasket only no rtv.
Old Jan 27, 2004 | 01:40 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
cork for me any day
Old Jan 27, 2004 | 01:53 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
take off your valve cover.
now put it back on.
it will then leak.
i just like rubber because theres no chance of a leak no matter how many times i reuse it.
Old Jan 27, 2004 | 02:27 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
I like the new rubber gaskets. I used to run the cork ones, but they start hardening when they get old and hot. They are also harder to clean off of the valve covers. The rubber ones seem to remain pliable. IMO.
Old Jan 27, 2004 | 02:44 PM
2 dope's Avatar
Engine: 305 LG4
now put it back on.
it will then leak.
i use gasket maker on both sides of the cork, ive taken them off a few times and still no leak
Old Jan 27, 2004 | 05:50 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I use the felpro rubber ones on my perimeter bolt valve covers and they work great. On the center bolt ones felpro makes the neoprine gaskets. I think those are the only type available for the newer style valve covers.
Old Apr 15, 2004 | 09:24 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
What about the FelPro Perma-Dry Plus (Part#VS12869T)? It is about twice the price of the FelPro rubber (Part#VS12869R). Is it worth it? What are the advantages?
thanks,
Old Apr 15, 2004 | 01:20 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I "glue" cork ones to the cover only with Hi-Tack. They are good for several R&Rs.
Old Apr 15, 2004 | 05:57 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Siliconized rubber.
I do like cork better on trans pans. It works swell.
Old Apr 15, 2004 | 06:36 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
If you have a machined surface on your heads for your rocker covers and are using NON stamped steel covers, the rubber/steel core ones are hard to beat.
Old Apr 15, 2004 | 06:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I don't use any... just put a bead of gasket silicone around the bottom of the valve cover, wipe the surface on the head clean-ish, drop it on and screw it down.
I do that, and I never have any leaking problems.
Old Apr 15, 2004 | 07:31 PM
ljnowell's Avatar
Well, I use cork ones, because they are cheap (usually I can find a set for free, because someone else bought rubber and dont need them), and because they are cheap. I also like them because they are cheap. Did I mention they are cheap? AirAdam, no gasket at all? Why?
Old Apr 15, 2004 | 08:01 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Rubber seals for everything.
Old Apr 16, 2004 | 02:26 PM
Air_Adam's Avatar
I've always had more success without them. Maybe I was doing something wrong, but I could never get rubber or cork ones to seal all the way around.
Since I started leaving them out and using only silicone, I've never had any leaks. Anywere.
Plus, its cheaper
Old Apr 16, 2004 | 07:30 PM
Car: 88 Camaro SC
Engine: SFI'd 350
They probably begin to leak after a while because they squish down when theyre repeatedly heated. Ive noticed mine doing the same thing and then they start to dribble. I usually jsut go back a week after ive installed the new gaskets and retorque the bolts to spec.
Old Aug 8, 2006 | 03:46 PM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
no chance?? I wish I could attain that.
which gaskets are you using and how do you prep the surface each time?
Old Aug 8, 2006 | 04:40 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
LOL, how old is this thread?
currently, i use the O-ring gasket that comes on the LS1... they never leak.
but on my SBC, i used the GM rubber gaskets. or the blue felpro rubber ones. i had flat, clean valvecovers, and flat clean valvcover rails.... no leaks that way.
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
