Timing chain at 105,000 miles
Old Jan 27, 2004 | 02:58 AM
joshwilson3's Avatar
Old Jan 27, 2004 | 04:52 AM
ede's Avatar
ede
if it ain't broke i wouldn't worry too much with trying to fix it. you don't need a roller chain. cloyes would be my pick for a chain and gear set.
Old Jan 27, 2004 | 10:10 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Its good insurence to replace a timing chain at 80k. It may not be broke yet but you dont want to pay for everything itll break when it breaks. Id go with just a stock replacement part. Double roller wont give you any power gain on a street engine.
Old Jan 27, 2004 | 12:33 PM
Old Jan 28, 2004 | 11:13 AM
dankhound's Avatar
Car: 91 RS
True roller wouldnt hurt.
Old Jan 28, 2004 | 12:37 PM
Damon's Avatar
I've got 220K and 190K on stock chaings in my various GM cars. Loose? For sure. Worth ripping into the motor to fix them? No way. Do it at your next full rebuild, unless it's gotten so loose that it's jumped a tooth.
I haven't found many chains under about $45 that don't stretch like salt water taffy in only a few thousand miles. This is one area where quality matters.
To give any chain it's best chance at living a long life submerge the chain in oil for 24 hours before installing it. The chain doesn't get much direct lubrication so you want to make sure it's well lubricated in those first few critical engine revolutions.
An even better way is to submerge it in a combination of oil and moly lube and bake it in the oven at 250-300 for a few hours. get your wife's permissions to use an old sauce pan and the oven before you do this or you could have other problems you never even thought of.
Old Jan 28, 2004 | 12:40 PM
Old Jan 28, 2004 | 02:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://store.summitracing.com/partde...art=CCA%2D3136
Old Jan 28, 2004 | 10:03 PM
25THRSS's Avatar
Isn't your factory chain roller anyways?
Old Jan 29, 2004 | 01:41 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Originally posted by joshwilson3
I can't find a cloyes true roller chain for a V8 engine. All the ones for chevy are for V6. Here's a link of what was pulled up at summit:
http://store.summitracing.com/partde...CLO%2D9%2D3145
http://store.summitracing.com/partde...CLO%2D9%2D3100
What do you think about this summit true roller timing chain:
http://store.summitracing.com/partde...rt=SUM%2DG6601
Would that one be a good one to get? And please post some part numbers on the cloyes timing chain set that would work for my car. I can only find ones for V6 engines.
Those Cloyes chains you linked to work on SBCs.
Old Jan 29, 2004 | 03:22 AM
Old Jan 29, 2004 | 05:49 AM
ede's Avatar
ede
after gm went to all steel gears i've never replaced one except when i had the engine apart for something else. never heard of one breaking, usually you'll see eratic movement of the timing mark when one wears.
Old Jan 29, 2004 | 12:07 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I agree with ede, if you have it apart, dont skimp, replace it. I have my motor out, with only 123,000 miles, and you could play jump rope with it. But if it aint broke, I wouldnt take the time to replace it.
Old Jan 29, 2004 | 12:50 PM
Old Jan 29, 2004 | 05:24 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My chain had about 100k on it... when I took the cover off, the chain litterally fell off it was so badly streched.
Got a good double roller on it now.
Old Jan 29, 2004 | 06:04 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I had a really old 350 a few years back.. car ran fine mind you.. developed a slight oil leak.. got it on ramps and looked for the leak.. there was a small hole through the side of my timing chain cover.. i pulled it off... that chain had so much slop in it it actually ate a hole through the timing cover.. no idea what the mileage was though.. it was one of those ****ty 350's where they put the nylon over the teeth weirdest part though i didnt even notice it jumped time..( it was a smogger 350 so it never had proformance anyway..) it didnt even backfire or give any signs of bad timing... lol
Old Jan 30, 2004 | 01:48 AM
Old Jan 30, 2004 | 01:59 AM
25THRSS's Avatar
Are 1989 305 V8 TBI engines a roller cam? Do I need to get a true roller timing chain? I was told that a single row is stronger than a double row, but a double row is lighter. Do you guys have a part number of the timing chain I need to get? And I'm looking at the brand Cloyes. All I can find on Cloyes are timing chains for V6's. So, I don't know what to get.
It's the other way around
Old Jan 30, 2004 | 02:36 AM
Old Jan 30, 2004 | 02:50 AM
25THRSS's Avatar
I dont understand how twice the chain and sprockets can be lighter?
Old Jan 30, 2004 | 02:55 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
The thing about timing chains is, when they skip a tooth, your car don't run. Then you call a tow truck, and they tow it to a garage where you pay top $$ to have a guy fix it.
I consider a timing chain replacement at over 100,000 mi. preventive maintenance, and a good excuse to put a cam and lifters in while you're there.
Old Jan 30, 2004 | 03:03 AM
Old Jan 30, 2004 | 06:09 AM
napalmdemos's Avatar
Car: 91 Firebird
Engine: 305 TBI
Check out Jegs I know they carry cloyes.
As for changing the timing gear and chain as preventive maintenance , mine is on its second after market chain set at 140,000.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
