Engine makes strange noise.
Old Jan 26, 2001 | 04:18 PM
HIX5000's Avatar
When my car is running I can hear a strange noise. It sounds like some kinda pump or something. Sometimes it's there sometimes it's not. My other Camaro dosen't make the noise at all.
1988 Camaro RS
2.8L five speed
Money pit from hell!!
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
Old Jan 26, 2001 | 06:38 PM
Blade's Avatar
Oh okay... well good of you to let us know
Old Jan 26, 2001 | 07:24 PM
HIX5000's Avatar
You are welcome smarty pants. Do you have any idea what could be causing this noise.
1988 Camaro RS
2.8L five speed
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
Old Jan 26, 2001 | 07:43 PM
MrF-body's Avatar
when you say it sounds like a pump do you mean it is a whining noise or is it a tapping noise? is it your automatic car or the 5 speed?
Old Jan 26, 2001 | 07:46 PM
Vader's Avatar
HIX,
Could be many things, from an alternator bearing or steering pump going, to a torque converter or trans oli pump on an automatic. It could even be a cooling fan.
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 26, 2001 | 07:51 PM
HIX5000's Avatar
it's the five speed, sorry forgot to mention that. It sounds like its coming from the back of the engine. It's kind of a tapping noise.
1988 Camaro RS
2.8L five speed
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
Old Jan 26, 2001 | 07:55 PM
Vader's Avatar
HIX,
It could be a throwout bearing. It could also be a distributor gear, oil pump (not as likely), a loose flywheel bolt or pressure plate bolt, excessive end play in the crank, or an input bearing in the transmission. If you can change the noise by disengaging the clutch, start looking at the clutch/flywheel/transmission. You might be able to isolate it further by removing the flywheel inspection cover and listening while the car is raised.
Later,
Vader
KaleCo Auto Parts
Old Jan 26, 2001 | 08:00 PM
HIX5000's Avatar
wow I have a lot to look at, Thanks vader. Pushing in the clutch has no affect on the noise.
1988 Camaro RS
2.8L five speed
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
red90IROCls1
Aug 25, 2015 06:56 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
