Help me figure this out.
Old Jan 28, 2004 | 08:13 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Posted this on the TPI board but not getting much help over there. Just out of curiuosity....What would cause you're car never to start on the first try after it sits for awhile. I can set there and crank and crank,probably till the battery dies,or just crank it for 3 seconds and it won't start. But on the second try, it will fire right up no problem. I also tried turning the key on and off a bunch of times trying to build up fuel pressure before starting it, but that had no effect.
Old Jan 29, 2004 | 05:08 AM
ede's Avatar
ede
my guess would be a fuel preasure or delivery problem
Old Jan 29, 2004 | 06:14 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
IIRC the pump only primes in the beginning and doesn't deliver more fuel until it fires. With a second attempt at starting you're getting another shot of fuel. I would agree with ede.
Old Jan 29, 2004 | 07:58 PM
Car: 92'Camaro RS
Engine: a loud one
Well what would cause a fuel pressure delivery problem?? The only thing i can see is maybe a clogged fuel filter or the intank fuel pump. But the fuel pump is a brand new AC Delco with maybe 1,500 miles on it and same with the fuel filter.
Old Jan 29, 2004 | 08:00 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I am curious about this too. My girlfriends car does the exact same thing and its brand new and has been taken to the dealership repeatedly with no resolve. You can hear the fuel pump prime but still nothing and its always done it from the beginning. The dealership even tested every single system with no problems found.
Old Jan 29, 2004 | 08:04 PM
Car: 92'Camaro RS
Engine: a loud one
ede.....could it be the injectors possibly?
Old Jan 29, 2004 | 08:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I had a similar problem for a long time and on my car, it was the coolant temp sensor was bad.
The Trickster!!!!!!!!!!!
Old Jan 29, 2004 | 08:36 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
what is the fuel pressure with the car not running? Whats the pressure reading when you turn the key to the run position?
Old Jan 29, 2004 | 08:40 PM
Car: 92'Camaro RS
Engine: a loud one
Not really sure, i have a fuel pressure gauge to check it, but the car is burried in snow right now. What's the norm for it to read when the car is off? Should it still be holding at least 35 lbs?
Old Jan 29, 2004 | 09:03 PM
89RsPower!'s Avatar
it should hold pressure unless you have a leaking injector(s), pressure regulator diaphram, etc...
Old Jan 30, 2004 | 06:01 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
43 psi stock
Bubbajones_ya
Jul 6, 2024 08:32 PM
earlpote
Sep 12, 2015 11:55 AM
Fronzizzle
Sep 8, 2015 12:10 PM
machinist21
Sep 5, 2015 03:03 PM
