Timing chain vs. Gear Drive...
Old Jan 29, 2004 | 02:13 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Which one would be better for a mild build. cam heads intake work, headers, full exhaust. Is it mostly for sound? I have heard cars with really noisy gear drives. Does it help peformance any? last longer than a regular timing chain? Whats the pros/cons here! Thanks fellas
Will
Old Jan 29, 2004 | 03:01 AM
3rdGenBlackBird's Avatar
I want to know also.
The previous owner put in a "noisy" gear drive. Sounds nice, but I can't imagine anyone who'd want to hear it all the time. I can live with it, but I prefer the full sleeper effect.
Old Jan 29, 2004 | 04:31 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
the gears dont streach,usually installed in old school blower cars they do keep the timing in check,drawback all that friggin noise and the worst part 20+hp loss,seen on a dyno...
Old Jan 29, 2004 | 04:57 AM
ede's Avatar
ede
depends a lot on how you define better, but if it were me i'd run a chain. double roller from cloyes if i was going for all out preformance i'd run a belt drive.
Old Jan 29, 2004 | 06:45 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No advantage whatsoever to a gear drive in a street motor. There's certainly no California street-legal motor you could build where it would do the slightest bit of good.
The main reason they're so popular is monkey-spank over the noise.
Run a good quality "true roller" (that sounds so stupid.... like "real butter" .... either it is a roller, or it isn't) timing set, not one of the cheap truck chains that looks sort of like a roller but only costs about $20. Those wear and "stretch" worse than a stock-type Link-Belt style of chain.
Cheapest way I know to get a known good quality timing set is a Comp 3100. It's about $45 or so.
Old Jan 29, 2004 | 07:42 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A gear drive can also trigger the knock sensor as picking up false knock. The car would then pull out timing and you would hurt performance.
Old Jan 29, 2004 | 09:10 AM
lowbgtRS's Avatar
Car: 94 Camaro
Engine: 383 Stroker
Alright, sounds like i wont be using the gear drive. Thanks alot for the help guys.
Old Jan 30, 2004 | 01:04 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Accroding to Cloyes they dont make gear drives for camaros with factory roller cams. The end of the cam has a smaller nose than you average flat tappet cam. So the debate is solved unless you weld the gear drive on.
Old Jan 30, 2004 | 02:02 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I had a gear drive in my truck engine thats now in the bird. It suited the truck fine but I dident want the noise in this car. I liked it but then again I was use to driving a 300-6 that has a factory gear drive just not as noisy at all speeds.
Old Jan 30, 2004 | 02:42 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
they might not
but others do.
Old Jan 30, 2004 | 02:51 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Double roller chain is more than enough for the street. They usually have steel gears (not nylon/aluminum like stock) and a heavy duty double row roller chain.
As far as street motors go, they are a much better choice than a gear drive because they are more than strong enough, cheaper, and less noisy than gears are.
Old Jan 30, 2004 | 02:56 PM
Air_Adam's Avatar
Comp cams double roller chain - $32.95 at Summit
This will be more than enough for a street motor, and is far cheaper than a gear drive set.
Old Jan 30, 2004 | 05:31 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
this is what i have in my blazer, along w/XR258HR w/comp roller lifters
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
