camshaft lube?
Old Jan 31, 2004 | 09:41 PM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
camshaft lube?
You guys that have rebuilt a few engines might know what I need to use. Anyway I'm putting my engine back together and it's one of those situations where I'm working on it between work and sleep. So, when your engine is going to set for a while during the rebuild, what do you lube the camshaft, lifters, etc. with so you won't get a dry start up. Of course I'll prime the oil pump before I crank it but I was trying to figure out what to coat the parts with that won't run off.
Old Jan 31, 2004 | 09:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What the cam mfr supplies; or assembly lube such as ARP's or GM EOS; or (what I end up using most often) white lithium grease.
Old Feb 1, 2004 | 06:25 AM
ede's Avatar
ede
i use moly lube or the cam grinders assembly lube on any metal to metal parts and lubriplate 105 on bearings and everything else. prelubing the engine might make you feel better but it's a waste of time.
Old Feb 1, 2004 | 08:11 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
This is probably different than most, but my father always used STP oil treatment on all the motors I saw him build, at least 20. I used it on the two I have done with positive results.
Its really thick and has worked for all the motors in his race car, race truck and his personal engines.
Old Feb 1, 2004 | 08:16 AM
ede's Avatar
ede
i think STP and ATF were all the lube that was ever used before real assembly lubes came along.
Old Feb 1, 2004 | 09:00 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
Good point, my father is 59 now and wouldnt even think of changing to EFI over a carb EVER....
Its just what I was taught
Old Feb 1, 2004 | 10:42 AM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
On this flat tappet cam, I used moly grease. On a roller cam motor I built before, I used straight STP oil treatmenmt.
The moly doesn't go anywhere, but the stp I found to run off a bit, and the stickiness of it isn't fun to work with.
For rod and main bearings, I mixed STP and 30HD oil in a 50/50 mix and used a small squirter oil can to apply it to my bearings. This made for a nice clean assembly process.
Old Feb 1, 2004 | 10:54 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
white lithium grease it were its at for me....my motor sat for periods during buildup and every time i went back the grease was right were i left it....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
ctoledo0834
Sep 18, 2015 04:16 PM
64Chief
Sep 12, 2015 08:05 AM
Randomtask2
Sep 7, 2015 05:06 PM
BOOT77
Sep 5, 2015 03:55 PM
