How much for a mechanic to change head gaskets on an L98?
Old Jan 25, 2001 | 02:33 AM
Dan87IROC-Z's Avatar
I think one of my head gaskets may be blown, but I don't feel like pulling them off, what would a garage charge to do that?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Jan 25, 2001 | 02:44 PM
daniel dekay's Avatar
lots, and lots
Old Jan 25, 2001 | 03:54 PM
Blade's Avatar
Too much ? YOu coud almost buy a pair of AFRs for how much a "garage" would ask to do it. lol
Here... I'll do it for you 1000 bucks sound good ? Okay... 999.99 ? LoL :P
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 26, 2001 | 12:21 AM
Ski89Z28's Avatar
Yea Blade is about right and I would agree about $1000.00 min!
You would do better doing it your self.
Good Luck.
Old Jan 26, 2001 | 02:13 AM
Dan91Z's Avatar
welp.. they want $290 just to change a fuel pressure regulator.. and all you have to do is take off a plenum.., so i don't even think i would want to know what a head gasket would cost...
My `91 Z28 Convertible
Old Jan 26, 2001 | 10:16 AM
Blade's Avatar
Daaaamn... and to take off the plenum takes what.. 30 minutes (if you take your time) ? Hehe
Old Jan 26, 2001 | 10:28 AM
Ski89Z28's Avatar
Yea, and to think how many times I took off my plenum if I charged myself I could have a new motor! Hehe
Old Jan 26, 2001 | 03:29 PM
I'm just gonna grin and bare it and change them myself, I got quoted at $600 to $800 from a local garage, thats just a tad too much.
L98 TPI 350 (5.7L)
Old Jan 28, 2001 | 10:16 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Doing it yourself will only cost under $100, complete, including fresh oil and filter.
Catch your old antifreeze - if it isn't TOO old - and reuse it.
I just pulled my heads last week just to do some minor grinding on the chambers. All my accessories remained in place (a/c compressor, alternator, p/s pump, water pump, etc.) and I only had to remove a few bolts that go through the accessory brackets into the heads.
Plenum and runner gaskets are reuseable.
Intake gaskets are $10, head gaskets are a little over $11.00 each, a tube of sensor-safe silicone sealant and maybe a gallon of antifreeze from AutoZone. You might need a new set of valve cover gaskets if you aren't running the rubber reuseable kind from Fel Pro or Detroit; they're the most costly items, about 30 bucks or so. Also, I always use Permatex #2 on the head bolt threads; so add in the cost of a tube of that gooey stuff ($2/$3)
I took a radio into the garage, tuned in my favorite station and had at it. Piece of cake.
Shoot me a line if you get stuck.
Hope this helps.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited January 28, 2001).]
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
