Buying car with Modified Engine
Old Feb 1, 2004 | 10:09 PM
CamaroSeeker's Avatar
Car: 89 Honda Crx:(
Engine: Hamster
Transmission: Wheel
Hello I'm looking at buying a 91 Camaro RS with the follow for $2000:
ENGINE: 1976 4-BOLT MAIN TRUCK BLOCK 5.7 LITER BORED 40-OVER
CAM DYNAMICS HIGH LIFT HYD CAM & LIFTERS, BILLET ALUM. ROLLER
ROCKERS, NEW FACTORY CAST HEADS WITH 3-ANGLE VALVE JOB, SWIRL
POLISHED VALVES, HIGH PRESSURE SPRINGS, EDLBROCK TORQUER II INTAKE,
1/2 INCH SPACER, HOLLY 750-4BBL CARB (PROGRESSIVE LINKAGE) HIGH
VOLUME/PRESSURE OIL PUMP, HIGH TORQUE MINI STARTER.
TRANS: 700R-4 WITH PERFORMANCE VALVE BODY
REAR: CUSTOM 10-BOLT WITH OVERSIZED AXEL TUBES, LARGE AXELS, 3:73
REAR GEAR ON POSSY SPOOL, AND REAR DISK.
ECM & WIRING HARNESS HAVE BEEN REMOVED.
CAR HAS: MSD IGNITION, COMP-LIGHT DISTRIBUTER, FLEX FAN, PERFORMANCE
WIRES WITH WIRE LOOM.
5" AUTOMETER TACH. WITH SHIFT LITE. AUTOMETER HOT ROD GAUGE SET
(FANTOM WHITE)
I'm gonna be putting a TPI setup on it and re-installing the ecm and the rest of the emissions components. Do you think this is a nice setup? and do you think this is a good deal for $2000(the car needs paint and a new door shell)? Thanks for your input!
Old Feb 1, 2004 | 10:12 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
I'd buy it but why TPI
Old Feb 1, 2004 | 10:27 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
If you are going TPI for emmisions reasons, the cost and labor may make it impractical. You will need the proper fuel pump and lines. The cam in that engine is probably not compatible. Headers or manifolds will need air tubes. etc etc. If you don't already have all these parts, add it up, before you jump!
Old Feb 1, 2004 | 10:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Possy spool"? Not sure what that is. "Posi carrier" or "spool", but not "posi spool".
"New factory cast heads"? Another "What exactly is that?" thing. Could be nice parts, or real performance-killers.
It sounds like too much money for something that needs that much work.
Old Feb 1, 2004 | 11:03 PM
Car: 89 Honda Crx:(
Engine: Hamster
Transmission: Wheel
Thanks for all the input! If $2000 for this car is too steep what would be a good price to offer the guy? and I know everyone says TPI chokes the hell out of a motor but what else could i put on there and stay emissions legal and still be a reliable daily driver? Thanks
Old Feb 1, 2004 | 11:27 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
camaro, dont even bring that up.... go do a search for carbs Vs. Tpi instead of starting another arguement lol... you arent suffering much gas mileage loss and its not "impossible" to get a carb to pass... yeah its easier with a tpi, but not that hard with a carb. plain n simple!
i would offer the guy 1500 for it with the back-up excuse on it needing the paint... but i'd for sure be happy with 1800 if the engine is what it is
Old Feb 2, 2004 | 12:35 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
It's not a matter of putting anything on it. You already have a carb, and if tuned, it should pass emissions. I've passed with half of what I could put out, for the last 4 years. But - no visual, but they do test for NOX now too!!!
But TPI has it's advantages too...more precise fuel control etc...
Seriously, either can pass a sniffer.....
Old Feb 2, 2004 | 04:49 AM
ede's Avatar
ede
sounds like the seller doesn't know what he has and some doesn't make sense at all. why buy it and then have to refit the ecm when you could find one with the ecm and tpi already there.
Old Feb 2, 2004 | 10:39 AM
Confuzed1's Avatar
Car: 83Z28 HO
I gotta agree....things like "NEW FACTORY CAST HEADS WITH 3-ANGLE VALVE JOB" and "HIGH PRESSURE SPRINGS" along with "CUSTOM 10-BOLT WITH OVERSIZED AXEL TUBES, LARGE AXELS, 3:73 " ......doesn't describe much. Not saying it's not true but the only way you'd know it had these things for sure is to take it apart.
Could be a junkyard 350 with a carb spacer, used Torker II intake, one legger 10 bolt, and had the ECM wiring ripped out.
Just playing devil's advocate....
Old Feb 2, 2004 | 02:41 PM
kd5boc's Avatar
Car: 92 RS
Hmmm...new factory cast heads...must have bought them from GM and had them polished and had the valve job done...
High pressure valve springs (if it has a cam with big lift)
Oversized axels? I've seen them on off-road trucks, but not on cars...unless the guy was making a track bullet.
I don't know...if I were you, I would ask for specifics before I buy...as far as EFI though...if it runs, don't bother it.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Linson
Aug 21, 2015 02:12 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
mustangman65_79
Aug 11, 2015 03:17 PM
MENINBLK
Aug 5, 2015 11:58 PM
