A very frightening CLICKING!!
Car: 2003 SVT Mustang Cobra
Engine: 4.6L DOHC Supercharged
Axle/Gears: 3.55
My '87 T/A is awesome. I have noticed that under the hood there is a CLICKING noise. Obviously it only does it when the car is on. It sounds like it's coming from the alternator but I can't be sure, any suggestions? Thanks.
It's all fun and games 'till someone looses an eye....then it's fun you can't see!!
1987 Pontiac Trans Am
-305 cid motor
-700-R4 Transmission
-K&N Air Filter
-Flowmaster 40 series
Muffler
-Yokohama Tires
-GTA Rims
-3" Exhaust Tips
-180 degree Thermostat
-2.73 Posi Rear End
-JVC Head Unit w/ Kicker subs!
-And a COOL LOOKING Flowmaster sticker on the dash!
WOO-HOO!!
*Long live the F-Body!*
-305 cid motor
-K&N Air Filter
Muffler
-Yokohama Tires
-GTA Rims
-3" Exhaust Tips
-2.73 Posi Rear End
WOO-HOO!!
Might be a lifter or an exhaust leak. If it's a lifter you'll want to make sure they are adjusted right(by tightening the loose ones). Just take it easy on the engine until you find out. You might want to put new lock nuts on them too to keep it from happening again.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
88 firebird formula
350 Vortec TBI
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
My Formula
It might be in the pulley system. You said that it sounds like the altenator. Take off the belt and spin the pulley. If it clicks or makes a grinding noise its probably bad. Someone correct me if I'm wrong
Pretty damn smart with cars for 17!
91 Camaro RS, 305 TBI
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
Edelbrock MPFI system.
RAM air hood & Z28 wing.
Z28 cam.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
Z28 cam.
ABS system.
Strutbrace.
Rollbar.
Take the belt off and start the engine. That will tell you if it's the alternator. If the noise is still there try the stick-o-wood stethascope trick and see if you can located the general area. Lifter? Exhaust leak? Try playing with the lifter adjustment while the engine is running, if the click changes pitch or tone then then tighten painfully slowly untill noise goes away. Still clicking? Exhaust leak?
Just don't let the engine run very long without the belt , No belt = No water pump
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Hard to determine. Guys are on track with the drive belt just for troubleshooting purposes. If it's TPI, those fuel injectors will click like no tomorrow - that would be normal.
Axle/Gears: 3.55
My 305 IS a TPI motor, so it's normal?
-305 cid motor
-K&N Air Filter
Muffler
-Yokohama Tires
-GTA Rims
-3" Exhaust Tips
-2.73 Posi Rear End
WOO-HOO!!
-305 cid motor
-K&N Air Filter
Muffler
-Yokohama Tires
-GTA Rims
-3" Exhaust Tips
-2.73 Posi Rear End
WOO-HOO!!
Car: 90 Camaro RS
Engine: 305 TBI
could be... but does it do it all the time or while warming up, or while revving or just in general. my TBI ticks like no tomorrow when i start it up....then the exhaust leak drowns it out....then my stereo drowns that out.
later
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
later
Rick
Linson
Oct 1, 2015 09:50 PM
Denricci22
Sep 18, 2015 09:02 AM
